Makera Two Flute Ball Nose Bit - 1/8 Shank 3.175mm * 22mm
Makera Two Flute Ball Nose Bit - 1/8″ Shank
  • Wood
  • Plastics
  • Composite materials, etc.
Product Description:
The two-flute ball nose bit allows for milling complex three-dimensional shapes, creating undercuts, or machining parts with intricate surface details.
Specifications:
  • Shank Diameter: 3.175 mm
  • Total Length: ~ 38 mm
  • Material: Solid Carbide
Applications:
  • Curve surface milling
  • Relief milling, etc.
Materials:
  • Wood
  • Plastics
Tool Reference Parameters:
* RPM: Spindle speed (RPM)
* Feed: Feed rate (mm/min)
* PFeed: Plunge feed rate (mm/min)
* DOC: Depth of cut (mm)
Specifications:
Tools Aluminum Brass Carbon Fiber Copper Hardwood PCB Plastic Softwood
1*4mm ball nose - - - - RPM: 12000
Feed: 500
PFeed: 200
DOC: 1
- RPM: 12000
Feed: 500
PFeed: 200
DOC: 1
RPM: 12000
Feed: 500
PFeed: 200
DOC: 2
1.5*8mm ball nose - - - - RPM: 12000
Feed: 500
PFeed: 200
DOC: 1
- RPM: 12000
Feed: 500
PFeed: 200
DOC: 1
RPM: 12000
Feed: 500
PFeed: 200
DOC: 2
2*12mm ball nose - - - - RPM: 12000
Feed: 500
PFeed: 200
DOC: 1
- RPM: 12000
Feed: 500
PFeed: 200
DOC: 1
RPM: 12000
Feed: 500
PFeed: 200
DOC: 2
2.5*15mm ball nose - - - - RPM: 12000
Feed: 500
PFeed: 200
DOC: 1
- RPM: 12000
Feed: 500
PFeed: 200
DOC: 1
RPM: 12000
Feed: 500
PFeed: 200
DOC: 2
3.175*22mm ball nose - - - - RPM: 12000
Feed: 500
PFeed: 200
DOC: 1
- RPM: 12000
Feed: 500
PFeed: 200
DOC: 1
RPM: 12000
Feed: 500
PFeed: 200
DOC: 2
Scope of Delivery:
  • 1x Makera Two Flute Ball Nose Bit - 1/8? Shank
Shipping weight: 0,13 kg
Item weight: 0,10 kg
Größe
€ 13,95
