Makera Two Flute Ball Nose Bit - 1/8 Shank
- SKU: MBS-MAK-10
- Category: CNC Milling Maschines & Accessories
Manufacturers:
Makera Two Flute Ball Nose Bit - 1/8″ Shank
- Wood
- Plastics
- Composite materials, etc.
Product Description:
The two-flute ball nose bit allows for milling complex three-dimensional shapes, creating undercuts, or machining parts with intricate surface details.
Specifications:
- Shank Diameter: 3.175 mm
- Total Length: ~ 38 mm
- Material: Solid Carbide
Applications:
- Curve surface milling
- Relief milling, etc.
Materials:
- Wood
- Plastics
Tool Reference Parameters:
* RPM: Spindle speed (RPM)
* Feed: Feed rate (mm/min)
* PFeed: Plunge feed rate (mm/min)
* DOC: Depth of cut (mm)
Specifications:
| Tools | Aluminum | Brass | Carbon Fiber | Copper | Hardwood | PCB | Plastic | Softwood |
| 1*4mm ball nose | - | - | - | - | RPM: 12000 Feed: 500 PFeed: 200 DOC: 1 |
RPM: 12000 Feed: 500 PFeed: 200 DOC: 2 |
| 1.5*8mm ball nose | - | - | - | - | RPM: 12000 Feed: 500 PFeed: 200 DOC: 1 |
| 2*12mm ball nose | - | - | - | - | RPM: 12000 Feed: 500 PFeed: 200 DOC: 1 |
| 2.5*15mm ball nose | - | - | - | - | RPM: 12000 Feed: 500 PFeed: 200 DOC: 1 |
| 3.175*22mm ball nose | - | - | - | - | RPM: 12000 Feed: 500 PFeed: 200 DOC: 1 |
Scope of Delivery:
- 1x Makera Two Flute Ball Nose Bit - 1/8? Shank
| Item information | Value |
| Shipping weight: | 0,10 kg |
| Item weight: | 0,10 kg |
