Matek Power Distribution Board (PDB)
  • three versions: FCHUB-6S, Micro PDB and PDB-XT60
  • power distribution
  • 5V and 12V outputs
FCHUB-6S
This power distribution board distributes power from a 3~6S LiPo pack to 4 ESCs and also provides regulated and filtered DC 5V and DC 10V outputs for powering cameras, RC receivers, flight controllers, video transmitters, LEDs, etc. In addition, it has a built-in 184A current sensor and provides an FFC connector to conveniently connect the MATEKSYS flight controller.
  • Input: 9-27V (3~6s LiPo)
  • Input TVS protection
  • PDB. 4x 30A (max. 4x 46A)
  • BEC 5V/ BEC 10V: 1,5A (max. 2A)
  • Current sensor: 184A
  • Current scale (1/10th mV/A): 179
  • Dimension: 46x36x4 mm
  • Weight: 9g
  • Mounting holes: 30,5mm, 3mm diameter
  • 1x FCHBU-6S
  • 4x M3x12
  • 4x M3x6+6
  • 8x M3 nuts
Matek Micro PBD
The Micro Power Hub is designed to provide the highest possible performance and reliability on a 36x36mm and 4-layer PCB. The hub distributes power from one battery pack to four controllers and provides two synchronized and regulated DC outputs to power cameras, servos, video transmitters, LEDs, etc. Batteries from 3S-6S LiPo can be used and the BEC input is TVS protected. The hub also has a convenient solder bridge with different voltages for the camera and video transmitter.
  • Input (2S-6S operation): 7.2-26V DC
  • Output: regulated 5V and 12V
  • LED power indicators
  • 4x ESC Outputs
  • Dimensions: 36x36mm
  • Weight: 6g
  • Mounting holes: 30,5mm square spacing
  • 1x Micro PDB
Matek PDB-XT60
The PDB-XT60 is designed to provide the highest possible performance and reliability in a 36x50mm and 4-layer board. It distributes power from one LiPo pack to 6 ESCs and provides synchronized and regulated DC 5V outputs and linear regulated DC 12V to power cameras, servos, RC receivers, flight controllers, Viedeo transmitters, LEDs, etc. It also provides XT60 socket for convenient connection of LiPo.Pack.
  • Input voltage (3S-4S LiPo): 9-18V DC
  • Outputs: regulated 5V and 12V
  • 6 ESC outputs and 1 pair of VCC/GND pads
  • Dimension: 36x50x4 mm (without XT60)
  • Mounting: 30,5x30,5 mm
  • Weight: 7,5g (without XT60), 11g (with XT60)
  • 1x PDB-XT60
PDF (3)
PDB FCHUB-6S Datasheet
Matek Micro PDB Datasheet
Matek PDB-XT60 Datasheet
€ 4,95
  • Available immediately
