MightyZAP Power Gender Jack
- SKU: MBS-Z-361
- GTIN: 0658917505011
- HAN: IR-AG01
- Category: Accessories
Manufacturers:
- Easy adaptation of standard 12 V power supplies (5.5/2.1 mm) to mightyZAP boards
The IR-AG01 is a power gender adapter for mightyZAP control boards. It provides the connection between an AC/DC power supply with DC barrel jack (5.5 mm / 2.1 mm) and the power terminal of the mightyZAP control boards. The adapter is assembled by the user – an assembly manual is included.
Before use, check that the barrel jack size of your power supply matches the specification (outer Ø 5.5 mm, inner Ø 2.1 mm). On the board side, an EC381V screw terminal is used. With a maximum current rating of 7.5 A, the adapter is also suitable for actuators with higher current consumption.
Technical Data
| Item | IR-AG01 – Power gender jack |
| DC barrel jack | Outer Ø 5.5 mm / inner Ø 2.1 mm |
| Terminal side | EC381V screw terminal |
| Max. allowable current | 7.5 A |
| Input voltage | 12 V |
| Packaging | Self-assembly kit (manual included) |
| Compatibility | mightyZAP control boards with power terminal |
| Manufacturer / origin | IR Robot Co., Ltd. / Korea |
Product Features
- Stable EC381V screw terminal on the board side
- High current rating up to 7.5 A – also suitable for stronger actuators
- Compact kit for easy self-assembly
Scope of Delivery
- 1× IR-AG01 Power Gender Jack (kit)
- Assembly manual
Note: The IR-AG01 is delivered unassembled and must be put together by the user according to the included assembly manual. Before connecting, make sure that the barrel jack dimensions (outer 5.5 mm / inner 2.1 mm) and the polarity of the power supply used match the mightyZAP control board.
