MightyZAP USB to Half Duplex TTL/RS-485 Converter
  • IR-USB03
  • USB Interface Card
The MightyZap IR-USB03 is a USB interface board that serves as a USB-to-RS-485 and half-duplex TTL converter. It enables the connection between a PC and MightyZap linear actuators. Using this interface, actuators can be configured, monitored, and tested with the Total Manager software.
The board replaces the older IR-USB02 model and offers several improvements, including a USB-C connector, an integrated termination resistor, and an enhanced electrical protection circuit.
The PC software supports the following functions, among others:
  • Setting of operating and system parameters
  • Configuration of memory and device parameters
  • Execution of motion and functional tests
  • Real-time monitoring of key operating data
  • Display of error messages
  • System initialization and firmware updates
Technical Data
  • Product type: USB to Half-Duplex TTL / RS-485 Converter
  • PC interface: USB Type-C
  • Device interfaces: TTL (Half-Duplex), RS-485
  • Communication speed: 9,600 – 115,200 bps
  • TTL / RS-485 signal level: 3.3 V
  • Supply voltage: DC 7 – 25 V (typical 12 V)
  • Supported actuator voltages: 7.4 V / 12 V / 24 V
  • Current capacity: up to 4 A
  • Overcurrent protection: 5.2 A
  • ESD protection (power supply): ±30 kV
  • ESD protection (communication): ±15 kV
  • Termination resistor: 120 Ω (switchable)
  • Operating temperature: −40 °C to +85 °C
  • Storage temperature: −40 °C to +105 °C
  • Dimensions: 56.4 × 54 × 16 mm
  • Weight: approx. 29 g
Scope of Delivery
  • 1 × USB Interface Board IR-USB03
  • Protective housing (engineering plastic)
  • Terminal connectors for actuator power supply
  • Documentation / datasheet (download)
Shipping weight: 0,40 kg
Item weight: 0,03 kg
€ 59,95
Docs MYBOTSHOP documentation
