The MTi-300 is our most powerful attitude and heading reference system. Thanks to its sensors and advanced sensor fusion algorithm, it delivers precise drift-free roll, pitch and yaw data with a true north reference.
As part of the MTi 100 series, the MTi-300 is characterized by its first-class, vibration-damping gyroscopes, which ensure high-quality orientation data even in demanding environments.
The MTi-300 has a robust design with an anodized, waterproof aluminium housing (IP67) and watertight connections. Special bolts facilitate mounting and alignment.
Sensor fusion performance
- Roll, pitch 0.2 deg RMS
- Yaw/heading 1 deg RMS
- Strapdown integration (SDI): Yes
Sensing components
- Gyroscope
- Standard full range: 450 deg/s
- In-run bias stability: 10 deg/h
- Noise Density: 0.01 °/s/√Hz
- Accelerometer
- Standard full range: 20 g
- In-run bias stability: 15 µg
- Noise Density: 60 µg/√Hz
- Magnetometer: onboard
- Barometer: OnBoard
System specifications (Mechanical)
- IP-rating (equivalent) IP67
- Dimensions 57 × 41.90 × 23.60 mm
- Weight 55 g
- Electrical
- Input voltage 3V3, 4.5 V–34 V
- Power consumption (typ.) 520 mW
- Interfaces / IO
- Interfaces USB, RS232, RS422, UART
- Protocols Xbus, ASCII (NMEA)
- Output frequency up to 2 kHz
- Movella Mit-300 AHRS Dev Kit
| Item information | Value |
| Shipping weight: | 0,50 kg |
| Item weight: | 0,06 kg |
