NVIDIA Jetson AGX Orin Industrial Box PC w/ 10G Ethernet - DSBOX-AGXMAX
  • up to 275 TOPS
  • AGX Orin 32GB, AGX Orin 64GB or AGX Orin Industrial
  • Connectivity: none, 4G or 5G
The Forecr DSBOX-AGXMAX is a rugged, fanless industrial box PC based on the NVIDIA Jetson AGX Orin SoM. With up to 275 TOPS of AI performance and best-in-class 10G Ethernet connectivity, it is built for demanding edge-AI applications – from machine vision through robotics and automation to autonomous systems.
Alongside the 10G port, the system offers 2× Gigabit Ethernet, USB 3.1, HDMI 2.0, CAN bus, serial (RS232/422/485) and MIPI CSI-2 camera support. The fanless design ensures reliable heat dissipation and protection against dust, shock and vibration; a wide temperature and input-voltage range makes the box PC suitable for harsh industrial environments. Made in Europe.
Supported modules NVIDIA Jetson AGX Orin 32GB / 64GB / Industrial
AI performance up to 275 TOPS (module-dependent)
Memory 32 GB or 64 GB 256-bit LPDDR5x
Graphics interface 1× HDMI 2.0 (max. 3840 × 2160)
Interfaces 2× Gigabit Ethernet · 1× 10G (SFP+) · 2× USB 3.1 Type-A · 1× CAN bus · 1× RS232/422/485 (software-configurable) · 2× USB-C (Debug/Recovery) · 2× Digital Input · 3× Digital Output
Wireless communication WiFi / Bluetooth / LTE / 5G via extension sockets
Extension sockets 1× M.2 Key-B, 1× M.2 Key-E, 1× SIM
Mass storage 64 GB eMMC 5.1 Flash · 2× M.2 Key-M SSD slot
Power supply 12–30 VDC
Operating temperature -25 °C … +55 °C (-40 °C with Industrial module)
Cooling fanless
Dimensions / weight 225 × 135 × 83 mm / 2000 g
Operating systems Ubuntu Linux 20.04, 22.04
JetPack support JetPack 5.x / 6.x
Manufacturing Made in Europe
Differences between the SoM options
Feature AGX Orin 32GB AGX Orin 64GB AGX Orin Industrial
Memory 32 GB LPDDR5x 64 GB LPDDR5x 64 GB LPDDR5x (ECC)
AI performance (INT8, sparse)* up to 200 TOPS up to 275 TOPS up to 248 TOPS
Temperature range -25 … +55 °C -25 … +55 °C down to -40 °C
Focus cost-efficient maximum AI performance extended ruggedness / long availability
* The TOPS figures (200/248/275) are the official NVIDIA module specifications (INT8, sparse); the Forecr page lists only the peak value of "up to 275 TOPS". The ECC property of the Industrial module also comes from the NVIDIA module specifications.
  • 1× DSBOX-AGXMAX industrial box PC with pre-installed NVIDIA Jetson AGX Orin SoM (per selected configuration)
  • depending on configuration: industrial SSD (256 GB / 512 GB / 1 TB / 2 TB) and 4G or 5G modem
Contact data
SOM Option
SSD
Connectivity
from
€ 4.165,00
  • Currently out of stock
