NVIDIA Jetson AGX Thor Carrier Board - DSBOARD-THRMAX
- SKU: MBS-ENTB-147
- Category: Development Boards
Manufacturers:
NVIDIA Jetson AGX Orin Industrial Box PC w/ 10G Ethernet - DSBOX-AGXMAX
- Carrier board for NVIDIA Jetson AGX Thor (T4000/T5000)
- QSFP28 (4 × 25 GbE), 6 × CAN-FD, up to 6 cameras
- 4 × M.2, optional Wi-Fi/BT and 4G/5G
- 18–36 V DC, -40 °C to +85 °C
Forecr DSBOARD-THRMAX – Carrier Board for NVIDIA Jetson AGX Thor
The Forecr DSBOARD-THRMAX is a compact, industrial-grade carrier board for the NVIDIA Jetson AGX Thor modules T5000 and T4000. With up to 2070 FP4 TFLOPS (sparse), it brings data-center-class computing power to robots, autonomous vehicles and smart city applications, on just 140 × 125 mm. The board is made in Europe.
QSFP28 with 4 × 25 GbE, up to six cameras, 6 × CAN-FD, four M.2 slots and an extended temperature range of -40 °C to +85 °C make the DSBOARD-THRMAX the foundation for demanding physical AI and sensor fusion systems, for example humanoids, AMRs or mobile inspection platforms.
Configurations
The board is fully configurable. All options can be combined:
| Option | Choice |
| Module (SoM) | without module · NVIDIA Jetson T4000 (64 GB LPDDR5X) · NVIDIA Jetson T5000 (128 GB LPDDR5X) |
| Industrial SSD | none · 256 GB · 512 GB · 1 TB · 2 TB |
| Connectivity | none · Wi-Fi/BT · 4G modem · 5G modem · Wi-Fi/BT + 4G · Wi-Fi/BT + 5G |
Highlights
- For Jetson AGX Thor: T5000 and T4000, up to 2070 FP4 TFLOPS (sparse), up to 128 GB LPDDR5X
- High-speed networking: QSFP28 (4 × 25 GbE) plus Gigabit Ethernet
- Multi-camera: expansion connector for 6 × 2-lane or 4 × 4-lane cameras
- Industrial interfaces: 6 × CAN-FD, RS-232/422/485, digital inputs and outputs up to 60 V
- Four M.2 slots: 2 × NVMe (PCIe Gen4), Wi-Fi/BT and LTE/5G, plus nano-SIM and GNSS
- On-board security and sensors: TPM 2.0, 6-axis IMU, temperature sensor, RTC
- Rugged: 18–36 V DC input, operation from -40 °C to +85 °C, USB-C with screw lock
- Software: Ubuntu 24.04 with NVIDIA JetPack 7.x
Technical specifications
| Supported modules | NVIDIA Jetson T5000, NVIDIA Jetson T4000 |
| Memory | 64 GB or 128 GB LPDDR5X, 256-bit (273 GB/s), depending on module |
| Display | 2 × HDMI 2.1, 2 × DisplayPort 1.4a (micro-coax) |
| Networking | 1 × Gigabit Ethernet (RJ45), 1 × QSFP28 (4 × 25 GbE) |
| Wireless (optional) | Wi-Fi, Bluetooth, LTE/4G, 5G, GPS/GNSS via expansion slots; 1 × nano-SIM |
| USB | 2 × USB 3.2 Type-C with screw lock, 1 × USB 2.0 Type-C (debug) |
| M.2 | 1 × Key-M 2280 (PCIe Gen4 x4), 1 × Key-M 2242 (PCIe Gen4 x2), 1 × Key-E 2230 (PCIe x1, USB 2.0) for Wi-Fi/BT, 1 × Key-B 3042/3052 (USB 3.0, USB 2.0) for LTE/5G |
| Storage (optional) | industrial SSD with 256 GB, 512 GB, 1 TB or 2 TB |
| Camera | 1 × camera expansion connector: 6 × 2-lane or 4 × 4-lane |
| Serial / CAN | 1 × RS-232/422/485, 4 × CAN-FD on board + 2 × CAN-FD on the expansion header |
| Digital I/O | 2 × digital inputs (11–60 V), 3 × digital outputs (low-side switch, up to 60 V) |
| Expansion header | 1 × I2C, 1 × I2S, 1 × SPI, 2 × UART, 2 × PWM, 2 × CAN-FD; 12 V fan connector |
| On-board | EEPROM, 6-axis IMU, temperature sensor, RTC (10+ year lifetime), TPM 2.0 (ST33TPHF2XSPI) |
| Power input | 18–36 V DC |
| Dimensions | 140 × 125 mm |
| Operating temperature | -40 °C to +85 °C (carrier board) |
| Software | Ubuntu Linux 24.04, NVIDIA JetPack 7.x |
- 1× Forecr DSBOARD-THRMAX carrier board
- depending on configuration: NVIDIA Jetson T4000 or T5000 module, industrial SSD, Wi-Fi/BT and/or 4G/5G module
