NVIDIA reComputer Carrier Board J202 for Jetson Nano/Xavier NX/TX2 NX
  • J202 (compatible with NVIDIA Jetson Nano/Xavier NX/TX2 NX)
  • Edge AI-Anwendungen
  • Comprehensive peripherals
  • alternative for the NVIDIA Jetson Xavier NX Dev Kit
reComputer J202 Carrier Board for Jetson Nano/Xavier NX/TX2 NX
This carrier board is similar in design and function to the NVIDIA Jetson Xavier NX carrier board. The J202 works perfectly with the Jetson Nano/Xavier NX/TX2 NX module. It also has USB3.2 Gen2 ports (4x), M.2 Key E (for WiFi), M.2 Key M (for SSD, RTC, CAN, Raspberry Pi GPIO 40pin, etc.).
The J202 can be used as an alternative for the NVIDIA Jetson Xavier NX Dev Kit, accelerating the development and deployment of the next AI application. With the help of its multiple camera ports, the J202 is suitable for running multiple neural networks in parallel for applications. These include image classification, object recognition, speech processing and segmentation.
  • Designed for Jetson Nano/Xavier NX/TX2 NX (260pin SODIMM)
  • Alternative to the NVIDIA Jetson Xavier Developer Kit
  • High versatility: suitable for complex AI graphics applications
  • Comprehensive certifications: FFC, CE, RoHS
Edge AI applications
The Jetson Xavier NX operates with up to 21 TOPS of AI performance. This enables it to develop and test energy-efficient, small form factor intelligent solutions with accurate, multi-modal AI inference in diverse industries.
Examples:
  • Pedestrian detection
  • Creating custom PPE detection and hard hat detection.
  • Pose estimation with alwaysAI
  • Visual anomaly detection with NVIDIA Deepstream IoT
  • Animal and wildfire detection
  • Recognition of objects in single line trade
Technical Data
  • Module Compatibility: Jetson Nano/Xavier NX/TX2 NX
  • PCB Size/Over all Size: 100mm x 80mm
  • Display: 1x HDMI+1x DP
  • CSI Camera: 2x CSI
  • Ethernet: 1x Gigabit Ethernet (10/100/1000M)
  • USB: 4x USB3.1 Type-A (10Gbps for NX, 5Gbps for Nano), 1x USB Type-C (Device mode)
  • M.2 Key M: 1x
  • M.2 Key E: 1x
  • FAN: 1x FanConnector
  • CAN: 1x
  • Multifunctional Port: 1x 40pin, 1x 12pin
  • RTC: RTC 2pin, RTC socket
  • Power supply: 12V/5A (Barrel Jack 5.5/2.1mm), Power cord provided only
  • NVIDIA reComputer Carrier Board
€ 204,95
