OpenMV AE3 Battery Shield
- SKU: MBS-SH-32
- GTIN: 05390368407173
- HAN: OMV-AE3-BATTERY-SHIELD-V7
- Category: Expansion Boards
Manufacturers:
- Power supply for the AE3: 6–36 V, LiPo or alkaline batteries
- Built-in LiPo charger
- microSD slot for data logging
- Standby current of just 12–16 µA
The OpenMV AE3 Battery Shield powers the OpenMV AE3 from almost any source: vehicle or system power up to 36 V, alkaline batteries, a 1S LiPo battery or USB. An integrated LiPo charger and a microSD card slot for data logging turn the AE3 into a self-sufficient AI camera for mobile and long-term applications.
The shield itself draws only a few microamps in operation. Combined with the AE3's deep sleep mode, this allows runtimes of up to several years on alkaline batteries, ideal for wildlife cameras, counting and monitoring systems or remote measuring points.
Highlights
- Three inputs: HV input (6–36 V), battery input (3.7 V LiPo) and LV input (1.8–5.5 V); HV and LV can be used simultaneously
- On-board LiPo charger: charges via the HV input or via the AE3's USB
- Battery operation: 3 alkaline cells in series or 1S LiPo
- microSD slot: for image and data logging directly on the device
- Extremely efficient: only 12–16 µA quiescent current
- Robust: reverse-polarity protection on HV and LV inputs, transient protection on all external interfaces
- Compact: 32 × 32 × 12 mm, 21 g, matching the AE3
Technical specifications
| HV input | 6–36 V, 2-pin JST; output 3.3 V up to 600 mA; reverse-voltage tolerant to -36 V |
| Battery input (BAT) | 3.7 V LiPo (1S); output 3.0 V up to 800 mA; not reverse-voltage tolerant |
| LV input | 1.8–5.5 V, 2.1 mm DC barrel jack; output 3.0 V up to 800 mA; reverse-voltage tolerant to -5.5 V; bypasses the charger |
| Batteries | recommended: 3 alkaline cells in series (on the LV input) or 3.7 V LiPo (1S) |
| Charger | BQ24075, charge current up to 100 mA, charging via the HV input or the AE3's USB (5 V) |
| Self-consumption | HV/USB at 5 V: 2 mA (not charging), 130 mA (charging) · LV at 5 V: 16 µA · BAT at 3.7 V: 12 µA (each without load) |
| microSD | SPI on P0–P3, power enable on P11; approx. 300 KB/s write, 100 KB/s read |
| Protection | transient voltage protection on all external interfaces |
| Dimensions / weight | 32 × 32 × 12 mm, 21 g |
| Temperature range | -25 °C to +85 °C (operation and storage) |
| Compatibility | OpenMV AE3 |
Notes: Four alkaline cells in series may slightly exceed the converter's maximum input voltage. With two cells, the shield shuts down before the batteries are fully discharged. Three cells are therefore recommended. The battery input is not reverse-voltage tolerant. Please observe the correct polarity.
- 1× OpenMV AE3 Battery Shield
