Opt Laser LaserDock PRO 16-pin
  • SKU: MBS-OPT-07
  • GTIN: 0658917515775
  • HAN: 006472 5902693114345
  • Category: Accesoires
  • Laser to CNC Magnetic Docking Station
  • Compatible with PLH3D-Series laser heads
  • Quick coupling and uncoupling
  • Automatic disconnection for protection in the event of collisions
Opt Lasers LaserDock PRO – magnetic docking station for laser heads on CNC machines
The LaserDock PRO is a magnetic quick-change station that lets you mount and remove laser heads on a CNC machine or robot in seconds, without tools. A position-locking system ensures the laser head sits in exactly the same spot every time it is docked.
The station transmits not only the electrical signals but also the compressed air for air assist. The long air hose is connected permanently to the LaserDock – a short connecting hose between the station and the laser head is all that is needed. This keeps the work area tidy and makes changeovers truly fast.
In the event of a collision, particularly in the Z axis, the laser head automatically detaches from the station, and the electrical contacts disconnect safely as well. When the laser is not in use, the included cover protects the CNC-side station from dust and damage.
  • Tool-free docking and undocking of the laser head in seconds
  • Magnetic mount with position locking for repeatable alignment
  • Integrated transmission of power, signals and air assist
  • Collision protection through automatic detachment, especially in the Z axis
  • Gold-plated, spring-loaded contact pins, recessed and redundant
  • Hole for a safety cable to prevent accidental falls – ideal for robotic applications
  • Compatible with all current and future Opt Lasers laser heads
  • Rugged, corrosion-resistant housing made of hard-anodized aluminum
Technical specifications
Mounting Magnetic, with position locking
Electrical contacts 16 gold-plated, spring-loaded pins
Media routing Power, signals and air assist
Collision protection Automatic detachment, especially in the Z axis
Material Hard-anodized aluminum
Compatibility Opt Lasers PLH3D series laser heads, e.g. XF+, XT-50, XT8
Manufacturer part number 006472
EAN 5902693114345
Notes
  • LaserDock PRO units and individual laser-side and CNC-side parts purchased before 2025 (8 instead of 16 pins) are not compatible with the current version. You can identify the version by the number of gold contact pins.
  • The LaserDock PRO is designed for heavier laser heads. Please take care to avoid collisions during operation.
  • 1× LaserDock PRO, consisting of CNC side and laser side
  • 1× cover for the CNC side
€ 194,95
