Orbbec Astra 2
- SKU: MBS-SES-291
- GTIN: 0658917502362
- HAN: 100100352
- Category: 3D Machine Vision
Manufacturers:
ORBBEC Astra 2
- structured light technology
- IMU and multi-camera synchronization
- Custom ASIC
- up to 1600x1200 @30fps
The Astra 2 3D camera from Orbbec is the successor to the Astra series products. It is based on structured light technology and has been equipped with the latest custom ASIC for high-quality deep processing. There is also the IMU and multi-camera synchronization. The Orbbec SDK simplifies setup and provides extremely accurate and reliable data for indoor use.
- Depth data output: 0.6m to 8m
- Up to 30 frames/s at 1600x1200 depth resolution
- Up to 30fps at 1920x1080 depth resolution
- Multi-camera synchronization
- IMU support
- Depth Range: 0,6m - 8m
- Depth FOV: 58,2° H x 45,2° V
- Depth Resolution/FPS: up to 1600 x 1200 @30fps
- IMU. supported
- Dimensions (WxHxD): 144,5mm x 45,3mm x 38,6mm
- Temperature: 0-35°C; 10%-95%RH (non-condensing)
- Power Input: USB 3.0 Type-C
- Power Consumption: average <3W
- Data Output: Point Cloud, Depth map, IR & RGB
- SDK: Orbbec SDK
- Weight: 241g
- Orbbec Astra 2
| Item information | Value |
| Shipping weight: | 0,60 kg |
| Item weight: | 0,24 kg |
All reviews:
- Available immediately
Delivery time: 1 - 3 Workdays (DE - int. shipments may differ)
