Orbbec Femto Bolt
- SKU: MBS-SES-287
- GTIN: 0658917502348
- HAN: 100100433
- Category: 3D Machine Vision
Manufacturers:
Orbbec Femto Bolt
- depth camera with 1MP ToF sensor and 120° FOV
- 6DoF IMU
- 4K RGB with HDR
- up to 15fps @ 1024x1024 or 30fps @ 640x576
The Femto Bolt from Orbbec is compact and powerful, with multi-mode depth and RGB cameras. For power and data forwarding, the Bolt has a USB-C port. The depth camera uses Microsoft's proven ToF technology. The also has the same operating modes and performance as Microsoft Azure Kinect and the Orbbec Femto Mega.
Applications
- Measurement: precise measurements of packages - improving shipping accuracy and logistics.
- Cobot: safe and intuitive interaction and response, precise object recognition and tracking > Cobots work safely and efficiently alongside humans
- Bin picking: locating objects in bins or on moving conveyors - facilitating the robot arm to pick up the objects
- Body scan: 3D full body scan
- Up to 15fps @ 1024x1024 or 30fps @ 640x576 depth resolution
- 4K RGB with HDR
- 6DoF IMU
- USB Type-C 3.2 for power and data transfer
- Sync trigger control for multi-sensor networks
- Depth Technology: ToF
- Wavelength: 850nm
- Depth Range: 0,25 - 5,46m (depending on Depth mode)
- Depth Resolution/FPS: uot o 1024x1024 @ 15fps (WFOV), 640x576 @ 30fps (NFOV)
- Depth FOV: H120° V120° (WFOV), H75° V65° (NFOV)
- RGB Resolution/FPS: up to 3840x2160 @ 25fps
- RGB FOV: H 80° x V 51°
- Processing: host computer
- IMU: supported
- Data Connection: USB 3.2 Type-C, Gen 1
- Power Input: USB Type-C/DC 12/2A
- Trigger: supported
- Power consumption: 4,35W average
- Operating Environment: 10°C - 25°C, Indoor/Semi-Outdoor, 8-90%RH (non-condensing)
- SDK support: Orbbec SDK
- Data Output: Point Cloud, Depth map, IR & RGB
- Dimension: 115mm x 40mm x 65mm (WxHxD)
- Weight: 335g
- Installation: Bottom: 1/4-20UNC | Side: 4 x M2,5
- 1x Orbbec Femto Bolt
All reviews:
- Available immediately
Delivery time: 1 - 3 Workdays (DE - int. shipments may differ)
