Orbbec SYNC HUB PRO
- SKU: MBS-Z-250
- HAN: 100400011
- Category: Accesoires
Manufacturers:
Product Information
- RJ45 Interface
- 1 x Multi-Camera Sync Hub Pro
- Switchable voltages when used with USB-C power supply
Multi-Camera Sync Hub Pro-Set
The Multi-Camera Sync Hub Pro-Set offers a compact and mountable solution for synchronizing multiple cameras. The housing stands out for its handy size and enables easy assembly.
Through the brilliant use of RJ45 interfaces according to industrial standards and the use of CAT5 cables or better, a reliable connection is ensured. This high-quality connection technology allows the synchronization of a primary device with up to eight secondary devices in a star format. If needed, the system can be expanded by connecting additional hubs to include even more devices.
The switchable voltage option when using a USB-C power supply provides flexibility and compatibility with various power sources.
The Multi-Camera Sync Hub Pro-Set includes 1 x Multi-Camera Sync Hub Pro. This combination allows for precise and reliable synchronization of multiple cameras, particularly advantageous in professional environments such as film productions or other multimedia applications.
