Ouster Multi-Layer 3D-LiDAR REV 7
  • SKU: MBS-SES-280
  • Category: LiDAR
Ouster 3D-LiDAR
  • OS0, OS1 & OS2
  • 64 & 128 Layers
  • Rev 7
  • Multi Layer LiDAR
  • ROS Support
  • Optimized for autonomous driving & Mapping
In case of ordering an Ouster LiDAR without integrating them into any second device, the "Terms of Sale" have to be signed and send back to us. These can be found HERE or under the paragraph "Downloads"
The Ouster Multi Layer LiDAR already enjoys a very large user base after a very short time on the market. Due to the wide product range, this LiDAR is suitable for almost any application where a large amount of data is required. In combination with the provided ROS interface, the acquired data can be further processed and transformed for the desired task area.
Improvements of Generation 2
With Generation 2, 128 layers are also possible in addition to the various features listed below.
  • Up to 128 Layers
  • Resolution: 0,35°
  • Accuracy +/- 1,5cm
  • Bigger FOV (Field of View)
  • Measurements > 0m possible (OS1)
  • High Performance Dynamik with which up to 10x more details can be captured
Differences to other competitors
In a direct comparison, the Ouster LiDARs are characterized by a sensational price/performance ratio. Competitors set their sales price, if they have a LiDAR in their range, which can keep up with the large number of layers of Ouster, at up to 10x (ten times). Nevertheless, there are only a few competitors in this market who have longer experience than Ouster, and because of this, still have some technical refinements.
Software Support
The Ouster 3D-LiDAR are not only of very high quality, but can also convince with very good software support. The US company provides a visualization tool for Windows, MAC & Linux as well as a Microsoft Visual Studio API, C++ library and full ROS support. As a result, the implementation of an Ouster sensor in a UGV (Unmanned Ground Vehicle) or UAV (Unmanned Aerial Vehicle) is possible within a very short time and in a very comfortable way.
Shipping weight: 2,00 kg
Item weight: 0,48 kg
Others (2)
Ouster Terms of Sale
Ouster Downloads
PDF (4)
Ouster Product Catalog
Datasheet Ouster OS0
Datasheet Ouster OS1
Datasheet Ouster OS2
Sensor
Resolution / Layer
from
€ 10.214,95
  • Available immediately
