Realman Combound Robot Mobile manipulator RM65 single arm with lifting system
  • SKU: ROB-RM-9
  • GTIN: 0658917513306
  • Category: Robot Arms
  • Single Arm with Lifting System
  • Advanced Performance: ARM A57 CPU, NVIDIA Maxwell GPU
  • Connectivity: WIFI, Ethernet, Bluetooth, USB, RS485
The Realman Compound Robot Mobile Manipulator RM65 with a single-arm lifting system offers an exceptional solution for demanding manipulation tasks in various applications. This mobile robotic arm is designed with a focus on flexibility and performance, making it highly useful in both industrial and research environments. Equipped with a powerful ARM A57 CPU and an NVIDIA Maxwell GPU, the RM65 guarantees high processing power and excellent graphics performance, making it ideal for various automation processes.
The robotic arm features an advanced lifting system that ensures precise and repeatable movements. With a maximum speed of 1 m/s and a repeatability of ±0.05 mm, it is suitable for a wide range of tasks that require both speed and precision. Thanks to its robust construction and the ability to control it via various communication protocols such as WIFI, Ethernet, Bluetooth, USB, and RS485, the RM65 can be easily integrated into existing automation systems.
The Realman Compound Robot Mobile Manipulator RM65 is the ideal choice for companies looking for a powerful and versatile solution for mobile manipulation and lifting applications. With support for common communication standards and flexible control, the RM65 enables easy integration into a wide range of industrial processes and applications requiring precise handling of loads.
Technical Specifications
  • Processor: ARM A57 @ 1.43 GHz
  • Graphics Processor: NVIDIA Maxwell @ 921 MHz
  • Memory: 16 GB RAM
  • Power Supply: 24V, 32A
  • Maximum Joint Speed: 225°/s
  • Repeatability: ±0.05 mm
  • Maximum Reach: 1 meter
  • Communication Protocols: WIFI, Ethernet, Bluetooth, USB, RS485
  • Dimensions: 90 mm * 25 mm * 25 mm
  • Maximum Load Capacity: 7.2 kg
  • Maximum Load on Arm: 20 N
Delivery Contents
  • Realman Compound Robot Mobile Manipulator RM65 with Single-Arm Lifting System
  • Power Supply and Connection Cables
€ 35.599,95
