Realman Combound Robot Mobile manipulator RM65 single arm
  • SKU: ROB-RM-10
  • GTIN: 0658917513313
  • Category: Robot Arms
Realman Compound Robot Mobile Manipulator RM65 Single Arm
  • High integration with mobile chassis, robotic arm, vision sensor, and dexterous hand.
  • Open software framework for easy development of custom applications.
  • Advanced safety features with obstacle avoidance, force sensors, and emergency stop.
The RealMan Compound Robot RM65 is an advanced mobile manipulator platform designed specifically for robotics and automation applications. With a powerful mobile chassis, a flexible robotic arm, advanced vision sensors, and a five-finger dexterous hand, this robot provides a versatile solution for various scenarios, such as robot mapping, navigation, trajectory planning, and visual recognition. Thanks to its open software framework, users can develop custom applications for their specific needs. The system is suitable for use in environments with different requirements and offers a user-friendly interaction that allows even less experienced users to quickly understand and operate the system.
Technical Data
  • Model: RMC-SA
  • Platform Size: Height: 1360mm, Arm Reach: 1040mm
  • Weight: approx. 72kg
  • Power Supply: DC24V
  • Positioning Accuracy: <±5cm
  • Safety Features: Laser scan obstacle avoidance, visual obstacle avoidance, force sensors, emergency stop
  • External Interfaces: Ethernet, USB, HDMI
  • Operating Environment: Temperature range: -10℃ to +40℃, Humidity ≤85% (at 25℃), Altitude <4000m
  • Maximum Speed: 1m/s
  • Vision Sensors: 1280x720@90fps, Working range: 0.3m to 3m
  • Robotic Arm: 6 Degrees of Freedom, Reach: 610mm, Payload: 5kg
  • End Effector: Four-finger grip strength: 0~10N, Thumb grip strength: 0~15N
  • Master Controller: NVIDIA Volta™ GPU with 384 cores, 6-core NVIDIA Carmel ARM®v8.2 CPU, 8 GB LPDDR4x RAM
  • Communication: Ethernet, WIFI, Bluetooth, USB, RS485
Scope of Delivery
  • RealMan RM65 Single-Arm Compound Robot Platform
€ 41.599,95
