Realman Combound Robot Mobile manipulator RM75 dual arms with lifting system
  • SKU: ROB-RM-8
  • GTIN: 0658917513276
  • Category: Robot Arms
  • Battery: 32Ah, Standby for 20 hours, Run for 11 hours at 0.7m/s
  • DoF: 7, Reach: 610mm, Payload: 5kg
  • Equipped with laser scanning obstacle avoidance and force sensors
The Realman Combound Robot RM75 is a mobile manipulator equipped with two powerful arms and a lifting system. This robot is designed to handle a wide range of tasks in various industrial and commercial applications. With its advanced sensors and motion control, it can precisely grab and lift objects. The manipulative arm of the robot offers exceptional reach and precision, making it suitable for use in a variety of environments. The RM75 is built for operation in demanding environments and provides reliable performance over extended operational times. Notably, it features advanced obstacle avoidance through laser scanning technology and integrated force sensors, ensuring safe and efficient handling.
The robot has high mobility and flexibility through the integrated chassis with eight wheels, allowing for differential driving and active suspension. This ensures stable and precise movement across different surfaces, making it an excellent choice for various applications in logistics, manufacturing, or research.
Technical Specifications
  • DoF (Degree of Freedom): 7
  • Reach: 610mm
  • Payload: 5kg
  • Equipped with: Laser-scanning obstacle avoidance and force sensors
  • Speed: 1m/s
  • Operating Temperature Range: -10℃ to +40℃, Relative Humidity ≤85% (at 25℃)
  • Communication: WIFI/Ethernet/Bluetooth/USB
  • Positioning Accuracy: <±5cm
  • Navigation: LiDAR with ±5cm accuracy
  • Max Joint Speed: 225°/s
  • Repeatability: ±0.05mm
Package Contents
  • Realman Combound Robot RM75 Mobile Manipulator with dual arms and lifting system
  • Wall charger and replacement battery
  • Controller unit with integrated GPU (Intel HD Graphics 4400)
  • USB and Ethernet cables for communication and remote control
€ 101.099,95
