SIYI FT24 Radio System
  • OTA receiver for wireless upgrades
  • Data Telemetry
  • PC software for configuration and upgrades
  • Multimode control
  • RC relay
  • USB simulator
The FT24 is based on the information base, which has increased over the years, this is SIYI Technology's industry-leading frequency technology here. The R&D team devoted to this remote control, especially for modelers and RC fans, new features. These include, for example, a particularly long transmission distance, a fast and stable response, such as high usability. The various model settings, advanced wireless communication and interactive functions make the FT24 very user-friendly.
Further capabilities are provided by expandable functions and a reserved interface to peripheral devices. To extend the range of functions, Bluetooth, Datalink, Digital FPV and an external multi-protocol high frequency tuner can be installed by the user.
15km Over-Horizon Control
The maximum control distance is 15km. This is due to the application of the latest technologies involving long range, self-adaptive bandwidth, interface avoidance, frequency hopping and two-way telemetry. In addition, the radio system is equipped with the industry-level RF hardware, which allows it to counteract electromagnetic interference. All these features ensure the stability of manipulation at this height when crossing trees or other obstacles. In addition, it is able to pass through concrete buildings.
Wireless communication & interactivity
To improve user experience, SIYI emphasizes wireless communication and interactivity. Therefore, such features have been integrated into the FT24 bracket: wireless binding, wireless OTA receiver update and configuration. In addition, wireless maser slave, wireless data copy, multi-model control, RC relay and others have been incorporated.
Multi-language, customizable voice Messaging
The built-in voice file is capable of translating important information, such as RSSI signal quality, undervoltage, settings, system status, etc., into multiple languages in real time. In addition, the user has access to personalized voices for power on/off, switch toggling, and data telemetry. Without having to check the monitor, the device is so easy to control and master. This can all be done via the TF memory card.
Wide range of model settings
  • for helicopters, gliders, multi-rotors, cars, boats, robotics, fixed-wings
  • programmable, powerful mix control
  • Different user-defined mix control settings
  • curve control settings
  • adjustable ratio (throttle curve-pitch curve processing) >quick adjustment of complex curve settings
  • data copy to TF card, easy sharing of settings
  • Master slave function with full protection
Technical data FT24
  • Transmission Distance: mx. 15km
  • Working Frequency: 2400-2483 GHz
  • Channels: 16 CH (12 physical)
  • Supported Models: Multi-Rotors, Planes, Gliders, Helicopters, Boats, Cars
  • Dimension (antenna folded): 191 x 175 x 64 mm
  • Weight (battery excluded): 586 g
  • Supported batteries: 2x 18650 Li-on batteries / 2S LiPo battery (XH 2,54 3-pin port)
  • Battery Slot size: 60 x 58 x 16 mm
  • Antenna Gain: 2dbi
  • Working current: 210ma
FR receiver
  • Real-time telemetry of battery voltage and receiver power supply.
  • By adding a Bluetooth module, the receiver can be connected to the serial port of the flight controller. The FT24 is thus able to receive and read out flight information telemetry based on the Mavlink protocol.
  • various signal output modes: 16CH SBUS, 8CH PWH, 8CH PPM
  • Firmware upgrade via PC USB port
  • wireless OTA upgrade via FT24 remote control
Technical data FR-Receiver
  • Signal Outpu: 16CH SBUS, 8CH PPM, 8CH PWM
  • Telemetry Port: UART
  • Dimension: 51,5 x 38 x 13 mm
  • Weight (antenna excluded): 20g
  • Rated Voltage: 5V-8,4V
  • Telemetry Voltage Range: 0-50V
  • Working Temperature: -10°C bis 55°C
FR Mini receiver
  • real-time telemetry of battery voltage and receiver power supply
  • OTA firmware upgrade via the FT24 remote control
Technical data FR Mini Receiver
  • Signal Output: 16CH SBUS, 8CH PPM
  • Dimension: 24 x 15 x 3 mm
  • Weight (antenna excluded): 1,5g
  • Rated Voltage: 5V
  • Telemetry Voltage Range: 0-26V
  • SIYI FT24 Radio System as chosen
from
€ 214,49
