SIYI MK32 Dual Enterprise Handheld Ground Station
  • SKU: MBS-SIYI-23
  • GTIN: 0658917501143
  • HAN: SYMK32-DR
  • Category: Accesoires
  • Dual Operator and Remote Control Relay
  • 7" 1000cd/m2 HD Monitor
  • Dual HD Digital Image Transmission
  • QualComm 8-Core CPU
The MK32 connection is based on SIYI's independent wireless HD image transmission technology. This is an all-in-one connection with integrated remote control, data connection and video streaming. The transmission technology has an intelligent function that can automatically adapt to the frequency band with the lowest interface.
MK32 Ground Station has a built-in 7" monitor with high brightness, as well as very high resolution. Information from the ground control software, as well as high quality images are displayed on the screen with a max. brightness of 1000nit (cd/m*2).
This Ground Station is equipped with an 8-core Qualcomm CPU, which is capable of decoding 1080p@60fps video streams in H.264 or H.265 format without any problems. The Android system has been upgraded to 4G RAM and 64G ROM, which can efficiently perform various ground softwares. For those who refer to HG wireless image transmission technology, SIYI enables the MK32 to have multiple connection functions.
The dual operator mode allows two MK32 ground stations to control the same air unit. Thus, one controls the flight position of the drone and the other controls the payload, such as gimbal camera or pods. In this mode, two Ground Stations can capture images from the same camera and from different ones. This mode can be used for UAV inspection, monitoring and remote delivery, etc.
Tehnical data
Overall
  • Model: MK32
  • Max. Transmission range: 15 km (unobstructed, free of interference)
  • Channels: 16 physical channels, 16 communication channels
  • Datalink compatible flight Controllers: Pixhawk / APM based flight controllers or any flight controllers with UART datalink Output.
  • Image Transmission compatible Android GCS: QGroundControl, SIYI FPV
  • Image Transmission compatible Windows GCS: QGroundControl, Mission Planner (H.264 only)
Ground Station
  • Monitor: 7" high-Definition and high brightness LCD touchscreen
  • System: Android 9.0 OS, 4G RAM & 64G ROM
  • Dimension (antenna overlapped): 308 x 148 x 72 mm
  • Weight: 1140 g
  • Battery Capacity & Type: 10200 mAh 7.4 V 2S Li-ion, 75,48 Wh
  • Fast charging protocol: PD 30W
  • Charging time: 3,5 h (30W PD charging)
  • Battery life: 10 h
  • Waterproof Level: IP4X
  • Working temperature: -10°C to 50°C
  • Interface&Ports:
    • Video Output:  Standard HDMI
    • External Device: USB-A
    • MIC Input: Top Audio Port
    • Charging: Type-C
    • Firmware Upgrade: Type-C
    • File Transfer: Type-C / USB-A
    • Mobile Network: SIM Card Slot
    • External Storage: TF Card Slot / USB-A
    • Communication: LAN (Ethernet)
    • RC Input / Output: Bottom Audio Port
Air Unit
  • Signal Output: 16 channels of SBUS, 5 channels of PWM
  • Dimension (antenna ecluded, fan included): 70 x 55 x 16 mm
  • Weight (antenna excluded): 74 g
  • Antenna gain: 5 dBi
  • Power Input: 12,6 to 25,2 V (expandable to up to 75,6 V with BEC)
  • Interface & Ports:
    • Remote Control: SBUS (GH1.25 3-Pin)
    • Datalink (to FC): UART (GH1.25 4-Pin)
    • PWM Channel 1 to 5: GH1.25 6-Pin
    • Video Input / Network Communication: Ethernet (GH1.25 8-Pin)
  • 2x MK32 Ground Station
  • 1x MK32 Air Unit
Shipping weight: 7,00 kg
Item weight: 5,00 kg
€ 1.699,95
