SIYI ZR10 Gimbal Camera
  • SKU: MBS-SIYI-13
  • GTIN: 0658917500955
  • HAN: SYZR10
  • Category: Accesoires
  • 30x hybrid zoom
  • Industrial-level 3-axis stabilization technology
  • HDR function
  • CMOS of 400 megabits
SIYI's ZR10 Gimbal Camera supports 30x hybrid zoom and is capable of providing a clear view over hundreds of meters. The fast and accurate algorithm has the ability to focus quickly and output high quality video.
The ZR10 has a CMOS of 400 megabits of effective pixels. The video resolution of the camera is up to 2560x1440. Recording is supported by a high-speed Class 10 MicroSD card.
The gimbal camera is equipped with industry-level 3-axis stabilization technology and high-precision FOC control algorithms. This results in the reduction of image shake. Even when the vehicle or aircraft is in strong motion, the images remain stable.
The High Dynamic Range (HDR) function can accurately capture details of shadows and highlights in dynamic scenes and can compensate for poor lighting conditions or backlighting accordingly. The very sensitive Starlight CMOS is able to keep the image bright even when lighting conditions are poor.
Possible applications:
  • Fire fighting and rescue
  • Traffic monitoring
  • Plant inspection (e.g. power poles)
Overall
  • Video Output Port: Ethernet
  • Control Signal Input Port: S.Bus / PPM / UART / UDP
  • Working Voltage: 11-25,2V
  • Power Consumption: 3W
  • Working Temperature: -10° ~50°C
  • Waterproof Level: IP4X
  • Dimension: 121 x 101 x 78 mm
  • Weight: 381g
Gimbal
  • Angular Vibration Range: +/- 0,01°
  • Controllable Pitch Angle: -90° ~25°
  • Mechanical Pitch Angle: -135° ~ 45°
  • Controllable Yaw Angle: -45° ~45°
  • Mechanical Yaw Angle: -90° ~90°
Camera
  • Lens: 10x Optical Zoom (30x Hybrid-Zoom)
  • Focal length: 5,55 +/- 5% bis 47,38 +/- 5% mm
  • Minimum Focus distance: 200mm
  • Image Sensor: 1/2,7", 4MP effective resolution
  • Aperture: F1,8 - F2,5
  • FOV: 79,5° (D), 71,5° (H)
  • TF Recording Resolution: 2K (2560 x 1440) @30fps
  • Video Storage Bitrate: 12Mbps
  • File Storage Format: FAT32
  • Image Format: JPEG
  • Video Format: MP4 (recorded in H265, *Auto converted to MP4 after Restart)
  • Still Photography Mode: Single
  • Metering Mode: Evaluative metering
marked with "*": in development and can be used later by firmware
  • SIYI ZR10 Gibal Camera
Shipping weight: 1,00 kg
Item weight: 0,38 kg
Contact data
€ 839,95
  • Goods ordered. 1 expected on 30.10.2026.
