Sabertooth 2x12A/6-24V Regenerative Motor Driver
  • SKU: MBS-M-08
  • GTIN: 0096718605187
  • Category: Electronics
Sabertooth Regenerative Motorcontrollerboard
  • 2x12A Power
  • 6-24 Voltage
  • 32KHz clocked
  • PWM & TTL Communication
  • Overcurrent protection
General
The Sabertooth 2x12A Dual Motorcontrollerboard is an very efficient driver module wich can be used in multiple ways espacially for robots based on wheels or chains up to 45kg. The Motorcontrollerboard is designed for a power consumption of 12A per DC-motor with a maximum power consumption of 25A.
Benefits & External Encoder - Module
The Sabertooth 2x12A Dual Motorcontrollerboard is provided with an overcurrent- & overtemperature protection wich automatically puts the Sabertooth controller into safety mode when exposed to high currents. In addition to that the transistors are clocked with 32KHZ wich results in a very silent operation.
The Sabertooth Controller can furthermore be enhanced with a Motion Controller (Kangaroo x2) to higher the positioning accuracy even more. the Motion Controller, wich can also hold an quadrature Encoder or Potentiometer, only has to be plugged onto the controllerboard.
Controlling
Due to the microcontroller supported controlling the Sabertooth Dual 12A Regenerative Motorcontrollerboard can be controlled via PWM signals or with a serial / TTL interface. Both the PWM signal and the interface can be found in every common singel-board computers and Atmel & ST uC's.
The selection of the kind of signal, the adjustment of the adress and baudrate can be done with the switches that can be seen below. The full documentation regarding the configuration can be found in the data sheet.
The full data sheet can be found HERE.
  • 12A continous, 25A peak per channel
  • Up to 24V input
  • Synchronous regenerative drive
  • Ultra-sonic frequency
  • Thermal and overcurrent protection
  • Lithium protection mode
  • Controlling via PWM Signals & TTL
Documentation
Software
Shipping weight: 0,10 kg
Item weight: 0,06 kg
Sabertooth Dual Regenerative Datasheet
€ 93,95
