Seeed Power Adapter Kit for reBot Arm B601-DM
  • SKU: MBS-Z1-274
  • GTIN: 05390368407166
  • HAN: 100029903
  • Category: Accesoires
  • 350 W at 24 V DC / 14.6 A – designed for the reBot Arm B601-DM
  • Wide-range input 90–264 V AC with 115 V / 230 V selector switch
  • Quadruple protection against short circuits, overloads, overvoltage and overtemperature
The Power Adapter Kit for the reBot Arm B601-DM is an industrial-grade AC/DC switching power supply with an output of 350 W. It delivers a stable 24 V DC at up to 14.6 A and is designed to power the reBot Arm B601-DM – including the load peaks that occur when several axes start moving at the same time.
The wide input range of 90 to 264 V AC with a selectable input switch (115 V AC / 230 V AC) allows operation on virtually any mains supply worldwide. Typical efficiency reaches up to 88 %; the integrated fan switches on according to thermal load and does not run continuously under partial load.
Comprehensive protection circuits against short circuit, overload, over voltage and over temperature safeguard both the power supply and the connected hardware. With an MTBF of more than 2,099,900 hours and compliance with IEC/UL 62368-1 and CCC (GB4943.1), the unit is also suitable for continuous operation in industrial environments.
Applications
  • Power supply for the reBot Arm B601-DM
  • Robotics workstations and development setups
  • Industrial automation and control systems
  • Test benches and electronic instrumentation
  • General 24 V DC supply in laboratory and workshop environments
Highlights
  • 350 W output power at 24 V DC and 14.6 A
  • Wide input range of 90–264 V AC with a 115 V / 230 V selector switch
  • Efficiency of up to 88 % (typical)
  • Fourfold protection against short circuit, overload, over voltage and over temperature
  • Thermally controlled fan for reduced noise under partial load
  • MTBF ≥ 2,099,900 hours
  • Compliant with IEC/UL 62368-1 and CCC (GB4943.1)
  • Compatible with power cords in US, CN and EU versions
Technical Data
Product Power Adapter Kit for reBot Arm B601-DM
Type Industrial AC/DC switching power supply
Output power 350 W
Output voltage 24 V DC
Output current 14.6 A
Input voltage 90–264 V AC (wide range)
Input selector switch 115 V AC / 230 V AC
Efficiency up to 88 % (typical)
Protection functions Short circuit, overload, over voltage, over temperature
Cooling Integrated fan with thermally controlled on/off operation
Standards and approvals IEC/UL 62368-1, CCC (GB4943.1)
Power cord Compatible with US, CN and EU versions
Compatibility reBot Arm B601-DM
Scope of Delivery
  • 1 × Power supply 350 W (24 V DC / 14.6 A)
  • 1 × Power cord (EU)
Shipping weight: 1,00 kg
Item weight: 0,76 kg
€ 84,95
