Segway Robotics RMP 401 PLUS
  • SKU: MBS-ROB-58
  • GTIN: 0658917513054
  • Category: Robot Arms
  • Modular design for easy integration with various sensors and components.
  • Automotive-grade suspension system for improved stability on rough terrain.
  • Long-lasting battery with up to 10 hours of operation and quick-swappable modules.
The Segway Robotics RMP 401 PLUS platform is an enterprise-grade mobile robotics platform specifically designed for developers and businesses looking to quickly and easily build autonomous robotic solutions. With a simple and easy-to-integrate chassis, the RMP 401 PLUS offers a flexible foundation suitable for both indoor and outdoor applications.
This platform has undergone rigorous testing and is built for demanding outdoor applications, making it especially robust and reliable. The RMP 401 PLUS is ideal for collaborative development projects or third-party developers who wish to adapt or reprogram the system for specific needs. Potential use cases include distribution, inspection, odometry services, cleaning, and warehouse automation (AGV), with options for individual customization and scalability.
The RMP 401 PLUS features an automotive-grade suspension system that, with double-wishbone suspension and hydraulic shock absorbers, enables stable navigation even on uneven terrain. This high-quality suspension minimizes vibrations and provides better traction and smooth movement over challenging surfaces.
The platform is equipped with a high-performance battery, allowing up to 10 hours of operation per charge. With an intelligent battery management system, based on over 400 million batteries managed globally, the battery is highly efficient. The quick-swap mechanism allows the battery to be replaced in just 30 seconds, ensuring extended operation times and minimizing downtime.
The RMP 401 PLUS drivetrain delivers power to all four axles, enabling smooth handling of rotation, inclines, and payloads. This makes the platform well-suited for applications requiring high stability and flexibility. Additionally, the RMP 401 PLUS offers developers a comprehensive API and ROS packages for control and navigation, facilitating easy integration and simulation of the chassis.
Technical Specifications
  • Modular components for easy adaptation to various applications.
  • Physical dimensions: 672 x 598 x 280 mm.
  • Wheelbase: 456 mm, track width: 545 mm.
  • Wheel diameter: 8 inches.
  • Ideal load: 28-50 kg.
  • Suspension: double-wishbone suspension with hydraulic shock absorbers.
  • Maximum range: 70 km.
  • Drive: four in-wheel motors.
  • Battery: 36V, 28.7Ah.
  • Charging: via chassis or battery unit itself.
  • Maximum speed: 3.56 m/s.
  • Minimum turning radius: 1.36 m.
  • Minimum braking distance: 1 m at 3 m/s.
  • Water resistance: IPX5.
Scope of Delivery
  • Segway Robotics RMP 401 PLUS platform.
  • Modular connectors for sensors and components.
  • Battery.
€ 5.819,95
