Stereolabs ZED Box NVIDIA® Jetson Orin™ NX 16GB with GMSL2 1TB with GNSS
  • AI Performance: 100 TOPS
  • GPU: 1,024-core NVIDIA® Ampere™ architecture with 32 tensor cores @918MHz.
  • CPU: 8-core Arm® Cortex®-A78AE @2GHz
  • DL accelerator: 2xNVDLA v2 @614MHz
  • Memory: 16GB LPDDR5 102.4GB/s
The ZED Box Orin™ series offers you the optimal solution for using the new ZED X GMSL2 cameras. With optional quad port GMSL2 interface, you can manage either two ZED X cameras or up to four single GMSL2 cameras.
The ZED Box Jetson Orin™ NX is perfect for indoor and outdoor applications, thanks to a variety of I/O options including USB 3.2, HDMI and PoE+. With the latest RTK-GNSS technology, it now also gives you high-precision autonomous navigation. Wi-Fi 6 and LTE/5G compatibility are offered through M.2 E-Key modules with 5 antenna ports, ensuring low latency and reliable wireless data transmission. With built-in PoE+ and ZED Hub remote control, the deployment and management of multi-camera edge deployments in Digital Twin and Smart Building projects is accelerated.
Specification
  • Includes 1x WiFi 6 connectivity
  • Power supply: PoE+ (25W) or DC-IN 5A 12-19V
  • NVIDIA® Jetson™ power mode: 10W | 15W | 25W
  • Passively cooled aluminum chassis
  • Dimensions: 118 x 92 x 71 mm (LxWxH) / 4.6 x 3.6 x 2.7 inches
  • Mounting options: 92x45mm mounting holes, wall (brackets included) and DIN rail mounting
  • Weight: 0.7 kg (1.5 lb)
NVIDIA® Jetson Orin™ NX 16GB Specification
  • NVIDIA® Jetson™ Orin NX 16 GB Module
Memory-Options
  • SSD 256GB (recognizable by the serial number with "D") or 1TB (recognizable by the serial number with "E")
GMSL2-Options
  • Quad port GMSL2 interface for 2x stereo cameras or 4x mono cameras (1 to 4 GMSL2 cables included)
  • 1x ZED Box NVIDIA® Jetson Orin™ NX 16GB
  • 1x GMSL2-Cable
GMSL2 port
Internal SSD storage
RTK GNSS GPS Ublox ED F9P
€ 3.999,00
Docs MYBOTSHOP documentation
