Stereolabs ZED X 120mm Stereo Camera without Polarization 2,2mm
  • SKU: MBS-SES-301-01
  • GTIN: 0658917599904
  • HAN: ZED-311110
  • Category: Sensors
  • Powerful IMU
  • IP66 protected
  • Multi-camera synchronization
  • Global Shutter with 1200p 60fps
  • Neural Depth Gen2
  • GMSL2 connector
The Highest Level of Perception
The new ZED X is an IP66-certified robot global shutter camera based on the Neural Depth Engine2. With its robust aluminum housing, powerful IMU, secure GMSL2 connection, and external image synchronization, it is ready to use in the field. The ZED X offers a frame rate of up to 120fps at 960x600 with a pixel size of 3µm. Capture every movement with the global shutter without sacrificing dynamics or image quality. No blurred or curved lines. Just perfect pixels in every scene.
Technical Data
  • Side by Side
  • 2x (1920x1200) @60fps
  • 2x (1920x1080) @60fps
  • 2x (960x600) @120fps
  • Interface: GMSL2
  • ZED X
  • Size: 1/2.6” sensors
  • Resolution: Dual 2.3M pixel sensors with 3-micron pixels
  • Format: 16:10
  • Shutter Synchronization: Electronically synchronized global shutter
  • 400Hz 16-bit accelerometer (up to 12g)
  • 400Hz 16-bit gyroscope (up to 1000°/s)
  • 2-year hardware warranty
  • Dimensions ZED X: 163.4 x 31.8 x 36.7mm (6.44 x 1.26 x 1.45”)
  • Weight ZED X: 239g (0.53lb)
  • Serial Coax GMSL2 connector - FAKRA Z type
  • 1/4”-20 UNC thread mount
  • 2x M3 threads (bottom)
  • 4x M4 threads (back)
  • Operating temperature: -20°C to +55°C (-4°F to 131°F)
  • Power via GMSL2 (PoC)
  • NVIDIA Jetson AGX Orin
  • NVIDIA Jetson AGX Xavier
  • Jetson Linux (L4T) v35.1 or newer
The ZED X can only be used with the Capture Card (selectable in the dropdown) or the ZED Box.
Package Contents
  • 1x ZED X (only)
Shipping weight: 0,50 kg
Item weight: 0,41 kg
PDF (3)
Stereolabs ZED 2 Datasheet
Stereolabs ZED2 ROHS
Polarization
Focal length
€ 714,95
Docs MYBOTSHOP documentation
