Stereolabs GMSL2 Capture Card Mono
  • SKU: MBS-Z-341
  • GTIN: 0658917513771
  • HAN: ACC-211000
  • Category: Accessories
  • Capture 1x GMSL2 camera input in SD/HD/4K up to 4K@30.
  • Up to 6Gb/s total bandwidth.
  • Connects to the CSI port of the carrier board through a 22pin 0.5mm pitch connector.
  • Includes JST to jack connector and CSI cable
High-performance GMSL2 capture card for connecting up to four ZED X cameras to all Jetson Orin and Xavier models.
  • High performance acquisition card specifically for Jetson.
  • Enables hardware synchronization between multiple cards at shutter level as well as the use of an external trigger or flash.
  • Requires an external power supply in the range of 12-19V
  • Supports the connection of 1x GMSL2 camera input in SD/HD/4K with a maximum resolution of 4K@30.
  • Provides a maximum total bandwidth of 6 Gb/s.
  • Connects via a 22-pin, 0.5mm pitch connector to the CSI port of the carrier board.
  • Includes a JST to female connector and a CSI cable.
  • Operating temperature: -20°C ~ +85°C
  • Weight: 8g
  • Dimensions (mm): 41,55 x 28 x 12,25 (LxWxH)
  • Power: external 5-19V DC
  • Deserializer: maxim MAX9296A
  • Interfaces: Interface J1 (Fakra): 1 GMSL2 I/O | Interface J4 (GPIO Header): 6pin 2mm pitch | Interface J1 (External 5V-19V) : Pitch 2 mm | Interface J2 (MIPI CSI pine) : 22pins 0,5mm pitch
  • Compatibility: use with NVIDIA Jetson Orin NX and Orin Nano Dev Kits and carrier boards | use with NVIDIA Jetson Xavier NX and Nano Dev Kits and carrier boards
Scope of delievery
  • 1x GMSL2 Capture Card Mono
  • 1x JST to jack connector
  • 1x CSI 22pin 0.5mm FFC cable (OP)
Shipping weight: 0,20 kg
Item weight: 0,01 kg
€ 165,99
Docs MYBOTSHOP documentation
