Stereolabs - ZED X One
  • 8MP Sony STARVIS 2 with a resolution of up to 4K at 15fps
  • Integrated high-performance IMU
  • Multi-camera hardware synchronization and trigger via GMSL2
  • Multiple S-Mount lens options
The ZED X One is the ideal choice for multi-camera surround vision or for flexible integration and customization of stereo systems across agriculture, logistics, and construction. This camera is designed to support high-precision and versatile applications, offering a range of features that make it a standout solution.
The ZED X One comes equipped with advanced sensor options that ensure top-notch image quality and performance. With the 2.3MP Global Shutter sensor, you can achieve resolutions up to 1200p at 60fps, while the 8MP Sony STARVIS 2 sensor provides resolutions up to 4K at 15fps. Both sensors are optimized for different needs and offer excellent image processing capabilities.
An integrated high-performance IMU (Inertial Measurement Unit) ensures precise motion tracking, while the hardware synchronization and trigger functionality via GMSL2 enable seamless multi-camera setups. The secure GMSL2 connection (1.5m cable included) not only provides connectivity but also power supply.
The ZED X One offers various field of view options: The Global Shutter has a wide field of view of 120.8°(D) x 110°(H) x 79.6°(V) or a narrow field of view of 120.8°(D) x 110°(H) x 79.6°(V). For 4K HDR applications, a wide field of view of 118.8°(D) x 109.9°(H) x 71.8°(V) is available. Multiple S-Mount lens options provide additional flexibility to tailor to specific requirements.
Compatibility with the ZED SDK (Software Development Kit) enables easy integration and extensive customization options for your specific applications.
Various Variations
Image Sensors:
  • Global Shutter
  • 4K HDR Rolling Shutter
 Field of View Options:
  • No lens
  • Wide
  • Narrow
 Specifications
  • Sensor option: 2.3MP Global Shutter with resolution up to 1200p at 60fps
  • Sensor option: 8MP Sony STARVIS 2 with resolution up to 4K at 15fps
  • Multi-camera hardware synchronization and trigger through GMSL2
  • Secure GMSL2 connection (1.5m cable included) with power
  • Field of view options:
    •   Global Shutter - Wide: 120.8°(D) x 110°(H) x 79.6°(V)
    •   Global Shutter - Narrow: 120.8°(D) x 110°(H) x 79.6°(V)
    •   4K HDR - Wide: 118.8°(D) x 109.9°(H) x 71.8°(V)
  • Compatible with the ZED SDK
  • 1x ZED X One
  • 1x 1.5m GMSL Female to Female cable
  • Adapter plate + Screws
Image Sensor
Field of view
from
€ 469,95
  • Available immediately
Others also bought:
Docs MYBOTSHOP documentation
