Unitree H2 Plus
Unitree H2 Plus
  • Sold by QUADRUPED
  • Available in different versions: Smart, Ultimate A–N
  • 31 base DOF
  • Arm torque 120 N·m
  • Payload up to ~15 kg
The H2 PLUS is the most powerful configuration level of the H2 humanoid robot. It combines the proven full-body platform with a factory-integrated NVIDIA® Jetson™ Thor high-compute module (2070 TFLOPS), making it purpose-built for demanding AI workloads, multimodal perception and physical AI. With a standing height of 1820 mm, a weight of around 70 kg and a bionic face, it combines a human-like stature with highly dynamic mobility. The build from aviation aluminum, titanium alloy and high-strength engineering plastic ensures a lightweight yet robust chassis.
In the base configuration, the H2 PLUS has 31 degrees of freedom (leg 6×2, arm 7×2, waist 3, head 2); industrial crossed roller bearings combined with low-inertia, high-speed PMSM motors enable precise, responsive motion with high torque. The quick-swap Li-ion battery (15 Ah, 0.972 kWh, max. 75.6 V) provides approximately 3 hours of runtime. The H2 PLUS is available as a base version (H2 PLUS Smart) and in the H2 PLUS Ultimate variants with factory-integrated dexterous hands.
Technical Data (Platform)
Dimensions (standing) 1820 × 456 × 218 mm
Weight approx. 70 kg (with battery)
Material Aviation aluminum, titanium alloy, high-strength engineering plastic
Degrees of freedom (base) 31 (leg 6×2, arm 7×2, waist 3, head 2)
Actuators Industrial crossed roller bearings + low-inertia high-speed PMSM motors
Max. torque Arm 120 N·m / Leg 360 N·m
Arm payload Peak approx. 15 kg / Rated approx. 7 kg
Limb length Leg 1045 mm / Arm 690 mm
Battery Li-ion 15 Ah, 0.972 kWh, max. 75.6 V, approx. 3 h runtime, air cooling
Sensing Bionic wide-FOV stereo camera, array microphones, high-power speaker
Connectivity WiFi 6, Bluetooth 5.2, OTA updates
H2 PLUS Smart (base version of the PLUS series)
The base version of the PLUS series is the development-ready platform with a factory-standard high-compute module. The compute architecture comprises two base compute units (Intel Core i5 for platform functions, Intel Core i7 for user development) plus the standard NVIDIA® Jetson™ Thor module. Secondary development is supported; dexterous hands and wrist camera are available as paid options.
Base compute PC1: Intel Core i5 (platform), PC2: Intel Core i7 (user development)
High-compute (standard) PC3: NVIDIA® Jetson™ Thor ×1
Optional compute PC4: empty, optional Intel Core i7 ×1
AI performance 2070 TFLOPS (FP4, sparse)
GPU 2560-core NVIDIA® Blackwell, 5th-gen Tensor cores, 10 TPC Multi-Instance GPU, max. 1.57 GHz
CPU 14-core Arm® Neoverse®-V3AE 64-bit, 1 MB L2/core, 16 MB L3, max. 2.6 GHz
Vision accelerator 1× PVA v3
Memory 128 GB 256-bit LPDDR5X, 273 GB/s
Storage NVMe SSD (PCIe), SSD (USB 3.2)
Video 2× NVENC (encoding), 2× NVDEC (decoding)
Dexterous hands optional (paid)
Secondary development supported
Scope of Delivery (H2 PLUS Smart)
  • 1× H2 PLUS (incl. NVIDIA® Jetson™ Thor)
  • 1× charger
  • 1× smart battery (quick-release)
  • 1× handheld remote controller
  • 1× lifting crane
H2 PLUS Ultimate – Variants Compared
The Ultimate variants include all features of the H2 PLUS Smart and are additionally supplied with two factory-integrated dexterous hands. Base compute (PC1 Intel Core i5, PC2 Intel Core i7), the standard NVIDIA® Jetson™ Thor module (PC3), secondary development and one wrist camera per hand are identical across all variants. The variants differ in the installed hand:
Variant Hand (2×) Type Tactile DOF/hand Total DOF Grip force Wrist camera
Ultimate A Dex1-1 Plus Gripper – 1 33 5–120 N Standard RGB
Ultimate B Dex3-1 3-finger – 7 45 – Standard RGB
Ultimate C Dex3-1 3-finger ✓ (33 sens.) 7 45 – Standard RGB
Ultimate D Dex5-1 5-finger – 16 63 10 N (fingertip) Standard RGB
Ultimate E Dex5-1 5-finger ✓ (94 sens.) 16 63 10 N (fingertip) Standard RGB
Ultimate F BrainCo Revo 2 Basic 5-finger – 6 43 50 N / 15 N Standard RGB
Ultimate G BrainCo Revo 2 Touch 5-finger ? 6 43 50 N / 15 N Standard RGB
Ultimate H Inspire DFQ 5-finger – 6 43 6 N / 4 N Standard RGB
Ultimate I Inspire E2 5-finger ✓ (17 sens.) 6 43 30 N / 28 N Standard RGB
Ultimate J BrainCo Revo 3 U21 5-finger – 21 73 70 N / 20 N Senyun SHF3L
Ultimate K BrainCo Revo 3 U21T 5-finger ✓ (0.01 N) 21 73 70 N / 20 N Senyun SHF3L
Ultimate L BrainCo Revo 3 U21VT 5-finger ? visuo-tactile (130 µm) 21 73 70 N / 20 N Senyun SHF3L
Ultimate M Wuji Hand 2 5-finger – 20 71 ≥ 15 N (fingertip) Standard RGB
Ultimate N Sharpa Hand 2 5-finger ? visuo-tactile 22 75 150 N / 20 N Senyun SHF3L
Wrist camera: „Standard RGB“ = FOV D:130° / H:120° / V:81°, 1920×1080. „Senyun SHF3L“ = HFOV 196°, 1920×1536 @ 30 fps, compatible with NVIDIA® Jetson AGX Thor.
Scope of Delivery (H2 PLUS Ultimate)
  • 1× H2 PLUS (incl. NVIDIA® Jetson™ Thor), 1× charger, 1× smart battery (quick-release), 1× handheld remote controller, lifting crane
  • 2× dexterous hands (depending on variant A–N) incl. wrist camera
Contact data
Price on request
  • Currently out of stock
