Virdyn mHand Pro
Virdyn mHand Pro
  • different sizes
  • S: Palm cicumference: 17-20cm | middle finger length: 7,5-8cm
  • M: Palm cicumference: 19-21cm | middle finger length: 8-8,5cm
  • L: Palm cicumference: 20-23cm | middle finger length: 8,5-9cm
Experience precise hand and finger movements in real time with our fully equipped mocap gloves. With 16 sensors on the back of the hands and fingers and the powerful “mHand Studio” engine, your gestures are directly translated into the movements of your 3D model. The fully self-developed gesture recognition system supports over 15 different gesture types and is ideal for VR content, game development, and 3D animation.
With SDK support, you can optionally use optical trackers for precise hand position tracking. The gloves are compatible with Windows and Android systems and offer maximum flexibility for developers and creatives.
  • Real-time hand and finger tracking with high precision
  • 16 sensors on the back of hands and fingers
  • Powerful “mHand Studio” engine transfers gestures directly to 3D models
  • Supports over 15 different gesture types
  • Ideal for VR content, game development, and 3D animation
  • SDK support for optional use of optical trackers
  • Compatible with Windows and Android systems
  • Maximum flexibility for developers, designers, and creatives
Technical Data
  • Implementation model: 9-axis inertial sensor
  • Number of sensor nodes: 8 nodes per hand
  • Capture range: ±180°
  • Capture accuracy: ROLL < 0.5° | PITCH < 0.5° | YAW < 15°
  • Gyroscope range: ±2000 dps
  • Acceleration range: ±16 G
  • Magnetometer range: ±4 Gs
  • Communication mode: 2.4 GHz wireless
  • Communication distance: Indoor ≤ 20 m | Outdoor ≥ 40 m
  • Data output frequency: 120 Hz / 96 Hz / 60 Hz
  • Data output type: Raw, Quaternion, Euler, BVH
  • Vibration motor function: 8 common vibration modes, supports user programming
  • Charger: 4.2 V charger
  • Power supply: Built-in 1050 mAh lithium battery
  • Battery life: ≥ 8 hours
  • Extended applications: C++ SDK, C# SDK, Unity3D, UE4.24–4.27, UE5.0–5.3, iClone7/8, Maya, Blender, MotionBuilder, 3DS Max, UDP broadcasting
  • Compatible headsets: HTC VIVE, Oculus Quest 2, Pico
Shipping weight: 0,70 kg
Item weight: 0,34 kg
Size
€ 1.549,95
