Wibotic TR-302 Edge Transmitter
  • SKU: MBS-Z-457
  • GTIN: 05390368407180
  • HAN: 030615
  • Category: Accessories
  • Wireless charging station with up to 300 W charging power
  • IP54 polycarbonate enclosure on a height-adjustable aluminum floor stand
  • Compatible with the WiBotic RX Coil Kits for Husky A200 and Jackal
The WiBotic TR-302 Edge Transmitter is the charging station for wireless charging of Clearpath robots with WiBotic. As soon as a robot with a WiBotic receiver coil is positioned in front of the station, the transmitter transfers the energy contactlessly. There are no plug connections and no manual intervention, which makes autonomous long-term operation much simpler.
The TR-302 delivers a charging power of up to 300 W. The electronics are housed in a polycarbonate enclosure with an IP54 protection rating and mounted on a height-adjustable aluminum floor stand. This allows the transmitter coil to be aligned precisely with the height of the receiver coil on the robot.
The actual charging power depends on how accurately the transmitter and receiver coils are aligned and on the distance between them.
Product WiBotic TR-302 Edge Transmitter (charging station)
Charging power up to 300 W (depending on coil alignment and spacing)
Enclosure Polycarbonate
Protection rating IP54
Mounting Adjustable aluminum floor stand
Operating temperature 0 to 40 °C
Compatible with Husky A200 – Wibotic RX Coil Kit
Jackal – Wibotic RX Coil Kit
  • 1× WiBotic TR-302 Edge Transmitter
  • 1× Adjustable floor stand
  • 1× AC power cable
  • 1× Ethernet cable
Note: For charging, the robot must be equipped with a suitable WiBotic RX Coil Kit (available separately). With its IP54 protection rating and an operating temperature range of 0 to 40 °C, the station is designed for indoor use or covered areas.
€ 3.579,95
