X540-270 Gear/Bearing Set
  • SKU: MBS-Z1-86-08
  • GTIN: 0618455051647
  • HAN: 903-0285-000
  • Category: ROBOTIS
Spare Parts for your DYNAMIXEL X540-270
  • Gear sets
  • bearing sets
  • gear ratio: 150 : 1
  • Made of coated metal
  • Not compatible with the DX/RX/MX series
Gear set for Dynamixel XH540/XM450 - gear ratio: 270 : 1
Existing gears can be replaced immediately after wear. These are made of metal and have been specially coated to improve durability and wear resistance. The special magnet for non-contact absolute encoder is attached to the gearbox.
Attention
  • Two ball bearings are used for the gears.
  • The bearing of the lower gear wheel is connected at delivery.
  • When replacing the gear wheel, mount it after connecting the upper gear wheel.
  • It is possible to recycle the used bearings, but it is recommended to use new bearings as the performance will be affected by abrasion, dirt, etc.
  • Because the Dynamixel X-Series uses non-contact magnetic encoders, you will need to calibrate the home position to align it after replacing the gear.
  • Use R+Manager2.0 to perform the calibration together with the calibration adapter.
  • These are not compatible with the DX/RX/MX series.
  • 1x X430 gear #1 (for 270)
  • 1x X430 gear #2 (for 270)
  • 1x X430 gear #3
  • 1x X430 gear wheel
  • 1x grease
  • 1x Calibration adapter - x540
  • 2x ball bearing
Bearing and Gear Sets
€ 180,95
