ROBOTIS DYNAMIXEL U2D2 Power Hub
- SKU: MBS-Z-57
- GTIN: 8809677570128
- HAN: 902-0145-001
- Category: Accesoires
Manufacturers:
ROBOTIS DYNAMIXEL U2D2 Adapter Board
- U2D2 slot
- plug systems DYNAMIXEL X-Series (TTL & RS485)
- Voltage supply via insolating screw joint or SMPS power adapter
The U2D2 Power Hub Board combines the diversity of connections for voltage supplies with the ROBOTIS U2D2 Adapter. The Power Hub Board has the same plug systems as the DYNAMIXEL X-series and also allows the connection of both TTL & RS485 servomotors. Furthermore it is possible to attach the U2D2 Adapter to the power board (48 x 57 mm) to reduce the danger of errors by disconnecting transmission cables.
- Dimensions: 48mm x 57mm
- Connetction voltage: 7,4V - 24V
- Max. Power: 10A
- U2D2 Power Hub Board
- rivets
- M3 Nuts
| Item information | Value |
| Shipping weight: | 0,03 kg |
| Item weight: | 0,02 kg |
All reviews:
- Item ordered. delivery date not yet announced by the manufacturer
Delivery time: 1 - 3 Workdays (DE - int. shipments may differ)
