DYNAMIXEL Pro+ PM54-060-S250-R
  • SKU: MBS-ANT-14
  • GTIN: 0096718606979
  • HAN: 902-0088-001
  • Category: Electronics
ROBOTIS Dynamixel Pro+ PM54-060-S250-R Servomotor
  • Resolution up to 502 834 Steps/Pulse
  • Position, Speed and Power sensor
  • RS485 Interface/Communication
  • Up to 28,3 RPM
General
The ROBOTIS Dynamixel Pro Servos have different power values, dimensions and interfaces and therefore cover a wide field of possible apllications. The Dynmaixel Pro+ M54P-060-S250-R has an epicyclic gearing aswell as an integrated encoder that enables up to 502 834 steps/pulse. Furthermore the Dynamixel Pro servos have following special functions:
  • current sensor for force control
  • control algorithm for speed, position and voltage regulation
  • PID-Controller for intern position control
The communication between the servomotor and the controling unit can be realised via the ROBOTIS Dynamixel U2D2, the ROBOTIS OpenCR1.0 or a variety of other Dynamixel Pro / RS485 compatible control units. One thing that should be kept in mind is, that the working voltage is 24 Volt.
Technical Data
  • Model Name: M54P-060-S250-R
  • ROBOTIS item number: 902-0088-001
  • Resolution: 502 834 Steps/Pulse
  • Weight: 0,855Kg
  • Dimensions: 54x54x126mm
  • Working Voltage: 24V
  • Maximum torque: 28,3 RPM
  • Current: up to 3,0A
  • Torque: 10,1Nm
  • Gear ratio: 251,4:1
  • Interface: RS485 (Half Duplex, 8bit, 1 Stop Bit, No Parity)
  • Working temperature: -5° - 55°C
  • ID: 0 - 252
The full manual of the Dynamixel Pro servos can be seen HERE.
Default settings
When delivered every DYNAMIXEL Pro servo has the ID:1 and a baudrate of 57 600bps.
  • DYNAMIXEL M54P-060-S250-R
  • 2 x 4P 600mm Data & Power cable
  • 20 x WB M3x8mm
Shipping weight: 1,50 kg
Item weight: 0,86 kg
€ 2.224,95
