ZED Box Mini
ZED Box Mini
  • with or without Wifi
  • Orin Nano 4GB/8GB
  • Orin NX 8GB/16GB
The ZED Box Mini is a compact and powerful embedded computing system based on the NVIDIA Jetson Orin™ modules.
It is specifically designed for AI-based visual applications and features all major I/O interfaces, including support for GMSL2 connectivity.
Its scalable and cost-efficient design makes it ideal for large-scale use in AI-supported robotics and visual systems.
Whether for autonomous robots or edge AI solutions, the ZED Box Mini offers the performance and flexibility to make your projects a success.
I/O Interfaces
  • 2× GMSL2 FAKRA-Z connectors*
  • 1× USB 3.0 Type-A
  • 1× Ethernet RJ45 (10/100/1000 Base-T)
  • 1× HDMI 1.4
  • 1× Micro USB 2.0 Type-B (for system flashing & OTG)
  • 1× GMSL2 camera synchronization trigger Input
  • 1× GMSL2 camera synchronization trigger Output
  • 1× 12V fan connector (mandatory when operating Jetson™ in MAXN mode)
  • Miscellaneous connectors: 1× CAN, 1× UART, 2× GPIO, 1× 5V, 1× 3.3V, 2× GND
General Specifications
  • Passively cooled aluminum case
  • Dimensions: 152.8 × 103.8 × 41.5 mm (L×W×H) / 6.02 × 4.09 × 1.63 Inches
  • Mounting holes: 92 × 45 mm
  • Weight: 600 g
  • Power supply: DC-IN 10.5V to 13.5V – max. 60W
  • Screw terminal block TBP01P1W-508-02GR
  • 256 GB SSD pre-installed (M.2 Key-M 2242 slot)
Available AI Modules
  • NVIDIA® Jetson™ Orin Nano 4GB
    • AI performance: 34 TOPS
    • Active cooling required in MAXN mode
  • NVIDIA® Jetson™ Orin Nano 8GB
    • AI performance: 67 TOPS
  • NVIDIA® Jetson™ Orin NX 8GB
    • AI performance: 117 TOPS
  • NVIDIA® Jetson™ Orin NX 16GB
    • AI performance: 157 TOPS
WiFi Option
  • WiFi 6 via Intel AX210 module
  • Mounted in M.2 Key-E 2230 Slot
  • Includes 2× 2.4/5 GHz WiFi antennas
Notes
  • * The ZED Box Mini supports only 1× ZED X One 4K input at a time.
  • 2× inputs are only compatible with all other camera models.
  • ** The Orin Nano 4GB/8GB variants currently do not support video streaming (encoding).
  • 1x ZED Box Mini
  • 1x Power Supply
  • 2x Sync Connectors (No cables)
  • 1x Micro-USB to USB cable
  • 2x 2.4/5GHz WiFi antennas (if WiFi is selected)
Shipping weight: 0,80 kg
Item weight: 0,60 kg
Contact data
Module
Wifi
from
€ 1.398,99
  • Currently out of stock
