AVerMedia D331 Kit
  • SKU: MBS-AVM-34
  • GTIN: 0658917504939
  • HAN: D331 Kit
  • Category: Electronics
AVerMedia D331ATB Box PC
  • Compatible with Jetson T5000™ / T4000™
  • CE, FCC, VCCI, KC (TBD)
The AVerMedia D331 Engineering Kit is the development-ready complete solution for the NVIDIA Jetson Thor platform: the D331 carrier board ships including the NVIDIA Jetson T5000 module, a 256 GB NVMe SSD and a power supply. With up to 2070 TFLOPS (FP4) of AI performance and 128 GB of memory, the kit brings Blackwell-class compute into a compact 190 x 190 mm form factor – designed for humanoid robots, autonomous mobile robots (AMR) and video analytics applications (VSS). The rich I/O set with QSFP high-speed networking, GMSL camera connectivity, CAN-FD and flexible expansion options enables rapid development and seamless integration of real-time sensor fusion and physical AI workloads. AVerMedia provides customizable BSP services and NVIDIA JetPack SDK support.
  • Complete engineering kit: D331 carrier board with NVIDIA Jetson T5000, 256 GB NVMe SSD and power supply
  • NVIDIA Jetson T5000 (Jetson Thor, Blackwell architecture) with up to 2070 TFLOPS (FP4) and 128 GB of memory
  • Designed for humanoids, AMR and video analytics (VSS)
  • High-speed networking: 2x GbE RJ-45 plus 1x QSFP with 4x 25 GbE (JetPack 7.2)
  • Extensive robotics I/O: 4x CAN-FD (1x isolated), 4x PWM, GPIO, UART, I2C and JTAG
  • GMSL camera connectivity via 120-pin interface (up to 8 cameras via optional GMSL board)
  • Flexibly expandable: Wi-Fi 6, 4G/5G, dual RTK GNSS as well as 8x PoE / 8x USB via daughter boards
  • Wide operating temperature range from -40 to +85 °C and 9–36 V DC wide-range input
  • TPM 2.0 onboard plus JetPack and BSP support by AVerMedia
Technical Data
AI module NVIDIA Jetson T5000 (Jetson Thor, Blackwell architecture)
AI performance / memory up to 2070 TFLOPS (FP4) / 128 GB
Networking 2x GbE RJ-45 (1x with OOB NCSI support); 1x QSFP: 4x 10 GbE (JetPack 7.1) or 4x 25 GbE (JetPack 7.2)
Wireless expansion 1x M.2 Key E 2230 (Wi-Fi 6); 1x M.2 Key B 3042/3052 (4G/5G); 2x SIM slots
Display 2x HDMI 2.0 (3840 x 2160 at 60 Hz)
Camera inputs 1x 120-pin connector for GMSL camera board (optional 8x GMSL via accessory)
USB 4x USB 3.2 Type-A (2x 5 Gbps, 2x 10 Gbps); 2x USB 3.2 Type-C (incl. BSP installation); optional 8x USB via daughter board
Storage 2x NVMe M.2 Key M 2280 (1x PCIe Gen4 x4, 1x PCIe Gen4 x2); 256 GB SSD included in the kit
Robotics interfaces 4x CAN-FD (1x isolated 3 kV), 4x PWM, GPIO, UART, I2C, 2x JTAG, 5 V / 3.3 V outputs
Audio 2x 3.5 mm jack (mic in, line out)
GNSS 1x mPCIe for optional dual RTK GNSS module (u-blox ZED-F9P+F9H)
Security TPM 2.0 (TI SLB9672) onboard
Power supply 9–36 V DC (terminal block 3-pin & Mini-Fit 6-pin), ACC/IGN control
Cooling 1x SOM fan, 2x chassis fan connector (12 V)
Operating temperature -40 to +85 °C (without audio) / -25 to +85 °C (with audio)
Dimensions / weight (board) 190 x 190 mm / 250 g
Certifications CE, FCC, VCCI, KC (TBD)
Scope of Delivery
  • 1x AVerMedia D331 carrier board
  • 1x NVIDIA Jetson T5000 module
  • 1x 256 GB NVMe SSD
  • 2x IO board
  • 1x power supply
  • Mounting accessories (screws and nuts)
  • Note: country-specific power cord not included
Shipping weight: 0,50 kg
Item weight: 0,25 kg
€ 10.679,95
Docs MYBOTSHOP documentation
