AVermedia PC Box D315AOB
  • versions: 32GB and 64GB
  • Edge PC with Fan
  • NVIDIA® Jetson AGX Orin (32GB / 64GB) & AGX Orin Industrial module
The AVerMedia Box PC D315AOB 5G is equipped with the NVIDIA® Jetson AGX Orin & AGX Orin Industrial module, providing next-generation AI performance and energy-efficient features for autonomous machines. This optional SoM enables advanced analytics and supports a variety of other embedded IoT applications.
The D315AOB 5G has a 120-pin high-speed connector specifically designed to connect MIPI SerDes cameras to meet the needs of autonomous mobile robots (AMRs) (adapter board and MIPI camera are not included). With 10G Ethernet bandwidth, the system is ideal for smart security applications and enables the simultaneous transmission of dozens of IP cameras. The 10GigE Vision camera connection is also ideal for intelligent inspection tasks. Despite its compact size, the D315AOB 5G offers a PCIe slot for multifunctional expansions and excellent compatibility with 5G and Wi-Fi 6.
AVerMedia devices are designed for flexibility and are suitable for the following markets:
  • Autonomous Mobile Robots (AMRs): AMRs use live camera feeds to quickly and flexibly adapt to work processes, significantly increasing productivity.
  • Intelligent safety: Using live camera feeds and video analytics to improve and ensure safety in communities.
  • Intelligent inspection: Live camera transmissions enable fast and precise detection, which optimizes quality control in production.
  • Type: BOX PC
  • NVIDIA GPU SoC Module Compatibility: NVIDIA® Jetson AGX Orin (32GB / 64GB) & AGX Orin Industrial module
  • Networking: 1x GbE RJ-45 | 1x 10G RJ-45
  • Display Output: 1x HDMI Output
  • Operating temperature -25°C~65°C
  • Storage temperature -40°C ~ 85°C
  • Relative humidity 40 °C @ 95%, Non-Condensing
  • MIPI Camera Inputs (Internal): GMSL2/FPD-link III/V-by-One® HS (STURDeCAM20 optional)* (*The adaptor board is not included but can be customized based projects. Please contact our sales team for more infomation.)
  • USB: 1x USB 2.0 Micro-B for recovery, 2x USB 2.0 Type-A, 2x USB 3.2 Type-A
  • Storage: 1x micro-SD card Slot
  • Expansion Header
    • 40-pin (UART, SPI, CAN, I2C, I2S, GPIOs )
    • 1x M.2 B key (for 4G LTE module or 5G module)
    • 1x M.2 E key  (for Wi-Fi 6E)
    • 1x M.2 M key (for SSD or AVerMedia capture card:  CN311-H, CN312SW, CN312MW)
    • 1x Micro SIM socket
    • 1x PCIe x16 (only support x8 PCIe lanes)
    • 1x CAN bus with transceiver
    • 120-pin (for MIPI SerDes)
    • OOB support
  • Voltage: DC 12V~54V
  • Power requirement: Current DC in JACK on board: 7A Max, ATX 4pin: 10.8A Max | DC in JACK on board: 7A Max, ATX 4pin: 10.8A Max
  • Thermal Solution: Fan
  • Buttons: Power and Recovery
  • RTC Battery: Support RTC battery and battery life monitoring by MCU
  • Dimension: 181.5mm (W) x 137mm (L) x 88mm (H) (with mounting hole)
  • Weight: 1.5kg
  • Certifications: CE, FCC, KC
  • D315AOB AVermedia
Shipping weight: 1,80 kg
Item weight: 1,50 kg
from
€ 3.214,95
