AgileX - Bunker Pro 2.0
  • SKU: MBS-AGX-23
  • GTIN: 0658917511388
  • HAN: Bunker Pro 2.0
  • Category: Robots on Wheels
AgileX Bunker Pro 2.0
  • High-performance robot with protection class IP67
  • Anti-collisions Design
  • Payload: 120KG
The AgileX Bunker Pro 2.0 is a state-of-the-art robot designed for demanding environments and versatile applications. With its robust construction and advanced technologies, it provides a reliable solution for various use cases.
Key Features:
  • High Performance and Reliability: The Bunker Pro is equipped with a powerful drive system that guarantees impressive performance and durability. Its robust construction makes it ideal for continuous use in demanding environments.
  • IP67 Protection Rating: The Bunker Pro has an IP67 protection rating, meaning it is completely dustproof and protected against temporary immersion in water. This makes it ideal for use in extreme and harsh conditions.
  • Anti-Collision Design: The Bunker Pro features an innovative anti-collision design that effectively prevents damage from collisions. This significantly increases safety and operational efficiency.
  • High Load Capacity: With an impressive load capacity of 120 kg, the Bunker Pro can easily transport heavy loads. This makes it an excellent choice for industrial applications and material transport.
  • Versatility: Thanks to its modular design, the Bunker Pro can be equipped with a variety of sensors and additional devices to meet specific tasks and requirements. This increases its flexibility and adaptability to different scenarios.
  • User-Friendliness: The Bunker Pro is easy to operate and maintain. Its intuitive control and user-friendly design allow for quick training and smooth operation.
  • Long Battery Life: Equipped with a powerful battery, the Bunker Pro offers long operating hours, minimizing downtime and maximizing productivity.
Applications:
  • Industry and Logistics: The Bunker Pro can be used in warehouses, factories, and other industrial environments to transport materials and perform logistical tasks.
  • Agriculture: Thanks to its robustness and versatility, the Bunker Pro is ideal for use in agricultural operations, such as harvest support or transporting agricultural products.
  • Construction: In the construction sector, the Bunker Pro can be used to transport building materials and tools and support construction projects.
  • Rescue and Security Services: Due to its high performance and reliability, the Bunker Pro can be used in rescue and security services, such as supporting search and rescue operations.
The AgileX Bunker Pro is a versatile and powerful robot suitable for a wide range of applications and environments. Its advanced features and robust construction make it an excellent choice for companies looking for a reliable and flexible robotic solution.
Technical Specifications
  • Dimensions: 1080*785*470mm (antenna excluded)
  • Gross Vehicle Weight: 225 kg
  • rated dynamic payload: 120 kg
  • Max Speed (loaded): 1,5 m/s
  • Max range: 15 km (full loaded), 20 km (unloaded)
  • Battery life: 2,5h (full load on concrete), 3,5h (unload on concrete)
  • External power Output: 72V 20A
  • Climbing capability: 30° (unloaded; stair-clinbing capable)
  • Obstacle clearance: 180 mm
  • Min Ground clearance: 120 mm
  • Operating temperature: -20°C to +60°C
  • IP: IP67
  • Drive motors: 2x 1800 W brushless servo motors
  • Battery type: 72 V / 50 Ah LiFePo Battery (Lithium Ion Phosphate)
  • Suspension System: Christie+Matilda 4-wheel balancing suspension
  • Braking System: servo brake
Scope of Delivery
  • AgileX Bunker Pro 2.0
  • AgileX Remote controller
Shipping weight: 300,00 kg
Item weight: 225,00 kg
Others (1)
Bunker Pro User Manual
€ 22.550,00
