AgileX Mobile Manipulator
  • Versatile mobile robot with integrated manipulator arm
  • Ideal for automation and research applications
  • Supports ROS/ROS2 for seamless integration
  • Real-time navigation and object handling
  • Modular design for various use cases
The AgileX Mobile Manipulator is an advanced robotic system designed for autonomous mobility combined with high-precision manipulation capabilities. It integrates a highly maneuverable AgileX mobile platform with a multi-joint robotic arm, making it suitable for a wide range of complex tasks in industry, logistics, research, and education. This system excels in dynamic, unstructured environments, offering exceptional flexibility and reliability.
Built entirely on ROS/ROS2, the platform is tailored for developers, engineers, and research teams working on custom automation solutions, AI-based robotics, or advanced vision systems. Its open architecture enables seamless integration of custom control algorithms, path planning, manipulation strategies, or machine learning modules into the existing software stack.
Equipped with various advanced sensors such as LiDAR, RGB-D cameras, and IMUs, the AgileX Mobile Manipulator enables real-time navigation and precise environment perception. It supports applications including multi-robot collaboration, human-robot interaction, and automated pick-and-place operations. This makes it ideal for deployment in smart factories, laboratory automation, and test facilities.
Thanks to its robust hardware, modular design, and powerful onboard computing, the system is ready for both indoor and outdoor use. Its comprehensive documentation and intuitive control interface make it an excellent solution for universities, technical colleges, and industrial research centers looking to explore and teach cutting-edge robotics.
Technical Data
  • Base platform: AgileX mobile chassis (e.g. SCOUT Mini, TRACER, or BUNKER)
  • Manipulator: 6-DOF robotic arm, optional with gripper or tool attachment
  • Control system: ROS / ROS2 compatible, preinstalled on onboard PC
  • Sensors: RGB-D camera, LiDAR, IMU, ultrasonic sensors, encoders
  • Power supply: Lithium-ion battery, runtime approx. 3–6 hours depending on setup
  • Payload capacity: Up to 10 kg (platform) / 2–5 kg (arm)
  • Communication: Wi-Fi, Ethernet, CAN-Bus, optional 4G/5G module
  • Operating system: Ubuntu Linux with ROS/ROS2, remote access via SSH or GUI
Scope of Delivery
  • AgileX Mobile Manipulator (mobile base + robotic arm)
  • Preconfigured onboard PC with ROS/ROS2
  • Sensor package: LiDAR, camera, IMU (depending on model)
  • Gripper or selected tool attachment
  • Battery charger and power adapter kit
  • Technical documentation and user manual (EN/DE)
  • Access to software updates and support portal (12 months)
€ 61.880,95
