AgileX T-REX 2.0
AgileX T-REX 2.0
  • wheeled-legged
  • Jump height: approx. 10 cm
  • Climbing ability: approx. 20°
  • Rated load: 1 kg
  • IP22
T-Rex 2.0 is a modern, versatile, and exceptionally stable rover designed for demanding outdoor missions, research, education, and industrial applications. Its robust chassis, powerful motors, and large all-terrain wheels ensure reliable movement even on uneven or difficult terrain. The modular design provides ample space for additional sensors, cameras, or computing modules, making the rover a flexible platform for a wide range of projects.
The T-Rex 2.0 is the ideal choice for anyone seeking a durable, adaptable, and expandable mobile platform for research, education, or autonomous outdoor projects.
Technical Data
Mechanical Parameters
Steering 2-wheel Differential
Size 269×341×215 mm (Min.) / 242×341×363 mm (Max.)
Weight 5.8 kg
Rated Load 1 kg
Axle Track 291 mm
Min. Ground Clearance 54 mm
Wheel Size 125 mm diameter
Suspension Type Adaptive Dynamics
Climbing Ability 20°
Obstacle Clearance 50 mm
Jump Height 100 mm
Operating Temperature −10 – 40 °C
IP Rating IP22
Brake Method Servo Brake
Power & Battery Parameters
Speed 1 m/s
Charging Time 2 h
Battery Life 2 h
Max Range 20 km
Outward Supply 24 V
Battery Capacity 21.6 V / 5 Ah
Battery Type Ternary lithium
Motor Type Direct-drive motor ×2, joint motor ×4
Specifications
  • Chassis & Structure:
    • Robust metal and plastic frame for outdoor use
    • Modular deck system for mounting electronics, sensors, and additional payloads
    • Large offroad wheels for high traction and terrain capability
  • Drive & Motorization:
    • 4 × high-performance DC geared motors (all-wheel drive)
    • Integrated wheel encoders for precise position and speed measurement
    • High ground clearance for uneven terrain
  • Electronics & Control:
    • Compatible with various flight and rover controllers (e.g., PX4, ArduPilot, Raspberry Pi, NVIDIA Jetson)
    • Flexible power supply for motors and electronics
    • Supports various add-on modules: GPS, cameras, LiDAR, telemetry, etc.
  • Dimensions & Performance:
    • Compact platform for easy expandability
    • Designed for demanding missions with medium payloads
    • Ideal for both indoor and outdoor use
  • T-Rex 2.0 Rover chassis (pre-assembled)
  • 4 × DC geared motors with encoders
  • Offroad wheel set
  • Mounting hardware & screws
  • Cable set for motors and electronics
Shipping weight: 7,00 kg
Item weight: 5,80 kg
€ 6.545,00
