ArduCAM 1MP OV9281 Mono Global Shutter 130deg M12
  • SKU: MBS-SES-185-24
  • GTIN: 0618455052187
  • HAN: B0224
  • Category: Sensors
  • Monochrome global shutter camera module with M12 mount lens inserts directly into the CSI slot of the Raspberry Pi
  • Supports Raspberry Pi 4, Pi 3/3B+/3A+, CM3/3+, Pi Zero and more
  • Only the Rev.B version supports the official V4L2 driver
  • The official V4L2 driver supports only RAW data and manual exposure
  • This camera and the RPI driver do not support hardware JPEG/H.264 encoding
  • The Raspberry Pi motherboard is not included in the package
The ArduCAM team has released a series of camera modules for the Raspberry Pi, including 5MP and 8MP modules. They are fully compatible with the official version and are divided into Standard Version, Optimized Optical Performance Version, Miniature Spy Camera Version, NoIR Version, Motorized IR Cut Version and Programmable Motorized Focus Camera Version. These camera modules support all Raspberry Pi models and require a 15-to-22 pin cable or adapter to work with the Pi Zero.
The Arducam monochrome (B&W) Global Shutter OV9281 camera module with a resolution of 1280×800 pixels is mainly designed for Raspberry Pi boards and can be directly connected to the CSI-2 camera interface of the RPi without any additional hardware.
This Arducam OV9281 global shutter camera (Rev.B) is compatible with the official V4L2 camera driver. NOTE: Only the Rev.B version supports the official V4L2 driver. Please use the Arducam MIPI camera driver for the first version.
The sensor's global shutter and excellent low-light sensitivity allow it to be used for any application that requires gesture recognition, head and eye tracking, and depth and motion detection.
Important:
  • This camera and RPI driver doesn’t support hardware JPEG/H.264 encoding.
  • The official V4L2 driver only supports RAW data and manual exposure.
Application:
  • Security
  • High dynamic range imaging
  • Unattended monitoring
  • Stereo vision
  • Machine vision
  • Automation
Technical data:
  • Sensor: monochrome global shutter OV9281
  • Pixel size: 3 μm x 3 μm
  • Active array size: 1280 x 800
  • Optical size: 1/4 inch
  • Focusing range: 30mm ~ infinity
  • IR sensitive: no IR filter, sensitive to IR
  • Lens FoV: 130°(D)/110°(H)/90°(V)
  • Output interface: Serial 2-lane MIPI output
  • Output formats: RAW
  • Maximum frame rate: 1280 x 800@120 fps with official driver/Arducam SDK.
  • Card size: 40mm x 40m
Scope of delivery:
  • 1x Arducam OV9281 1MP monochrome global shutter camera module with 130deg M12 connection lens
  • 1x 150mm 15pin 1.0mm to 22pin 0.5mm pitch FPC cable
  • 1x 80mm 22pin 0.5mm pitch FPC cable
€ 72,95
