ArduCAM NVIDIA Jetson Dual OV2311 Mono GS Stereokamera
  • SKU: MBS-SES-192-12
  • GTIN: 0618455044120
  • HAN: B0264
  • Category: Sensors
ArduCAM NVIDIA Jetson Stereokamera
  • EOL: Rplacement:  B0365N
  • Dual Stereokamera
  • Monochrome
  • Global Shutter
  • OV2311
The ArduCam 2MP Stereo Camera Module is a module with two 2MP synchronized monochrome global shutter OV2311 image sensors. It achieves higher accuracy and frame rate when extracting depth information. This is made possible by the monochrome sensor's ability to deliver excellent detail and sensitivity.
Application areas: Depth detection, SLAM, 3D mapping, 360° cameras, VR/AR applications, etc.
  • Full synchronization
  • Mono Global Shutter: capture moving objects in sharp Images.
  • ISP processing function is supported on Raspberry Pi platform, max frame rate is 50fps @3200x1300
  • ISP processing function is not supported on NVIDIA Jetson platform, max frame rate: 50fps @3200x1300
Support Platform Raspberry Pi and Jetson Nano
Output/CSI-2 Speed x1 CSI-2 2-lane Output Port/1.0 Gbps/Lane
Output Formats RAW8/RAW10/RAW12
ISP Support Supported on Raspberry Pi, not supported on Nvidia Jetson
External Triggle Support
Aggregate mode Full Spelling Combine
Frame Rates(On Raspberry Pi) Raw8/Raw10: 3200×1300@40fps, 3200×1080@80fps, 2560×720@80fps
Frame Rates(On Nvidia Jetson) Raw8/Raw10: 3200×1300@40fps, 3200×1080@80fps, 2560×720@80fps
Image Sensor Monochrome Global Shutter 2MP OV2311
Pixel Size 3 μm x 3 μm
Active Array Size 1600 x 1300
Optical Size 1/2.9”
Focus Distance 30mm-infinite
Camera Interface 2-lane MIPI CSI-2
Camera Board Size 105(L) x 24(W) x 20.1(H) mm
Default Lens Mount M12 Mount
Distortion <1%
Effective Focal Length 2.8mm
Focus Type Manual Focus
Field of View(FOV) 83° (H) x 67.5°(V)
IR Sensitivity Without IR-cut filter, sensitive to IR light
F.NO 2.8
Default Lens Low distortion M12 lens (Part Number: M27280M07S)
  • 1 pcs Arducam 2MP OV2311 Stereo MIPI Camera Module with low distortion M12 Mount Lens
  • 1 pcs 150mm 15pin 1.0mm pitch FPC cable
  • 1 pcs 150mm 15pin 1.0mm to 22pin 0.5mm pitch FPC cable
Contact data
€ 229,95
  • Currently out of stock
Docs MYBOTSHOP documentation
