ArduCam IMX335 MIPI Camera Module for RPi
  • SKU: MBS-SES-185-47
  • GTIN: 05390368407234
  • HAN: B0568
  • Category: Sensors
Arducam 5MP IMX335 Low Light MIPI Camera Module for Raspberry Pi
  • Sony STARVIS IMX335 – 5 MP (2592 × 1944) @ 30 fps
  • Good low-light performance thanks to 2.0 µm BSI pixels
  • Pre-tuned M12 wide-angle lens (104.9° D) with 650 nm IR filter
  • Open source: upstream libcamera driver, schematics & 3D files
  • For Raspberry Pi 5 / 4B / 3B+ / 3 / 2 / CM3 / CM4 / Zero W / Zero 2 W
The Arducam IMX335 MIPI Camera Module (B0568) is a 5-megapixel open-source camera for Raspberry Pi and embedded Linux systems. At its heart is the Sony STARVIS IMX335, a back-illuminated 1/2.8″ sensor with 2.0 µm pixels that delivers detailed, sharp images at 2592 × 1944 pixels and 30 fps – even indoors, at dusk or under controlled lighting.
The module ships with an M12 wide-angle lens pre-tuned for the sensor (104.9° diagonal, F1.6, fixed focus from 1.9 m) and an integrated 650 nm IR-cut filter for accurate colour reproduction under normal lighting. Thanks to the M12 mount, the optics can be swapped for other M12 lenses if required.
The camera is fully open source: it is driven by upstream libcamera drivers – a single “dtoverlay=imx335” entry in config.txt is all it takes, no proprietary kernel driver required. Arducam provides full schematics and 3D files, and via rpicam-apps or Picamera2 the module integrates directly into your own vision pipelines. The active libcamera community supports custom ISP tuning.
Typical applications include industrial inspection, smart traffic systems, surveillance and security, agricultural technology and embedded vision prototyping.
Technical Data
Image Sensor
Sensor Sony STARVIS IMX335 (back-illuminated, BSI)
Resolution 5 MP (2592 × 1944)
Optical Size 1/2.8″
Pixel Size 2.0 µm × 2.0 µm
Output Format RAW10 / RAW12
Video Mode 2592 × 1944 @ 30 fps
Shutter Type Rolling shutter
Colour Filter Colour (RGB)
Optics
Focus Fixed focus
Lens Mount M12 (S-mount)
Focal Length (EFL) 4.3 mm ± 5 %
Aperture F1.6 ± 10 %
Field of View (FoV) 104.9° (D) × 82.4° (H) × 53° (V)
Focus Range 1.9 m to infinity
IR Filter Integrated 650 nm IR-cut filter
Electrical & Mechanical
Interface MIPI CSI-2
Operating Voltage 3.3 V
Power Consumption 1 W
Operating Temperature −10 °C to +60 °C
Board Size 24 mm × 25 mm
Software & Compatibility
Driver Upstream libcamera (dtoverlay=imx335), open source
Operating System Raspberry Pi OS Bookworm – image from 6 May 2025 or later, kernel ≥ 6.12.25, libcamera ≥ 0.5.0+rpi20250707-4
Supported Platforms Raspberry Pi 5 / 4B / 3B+ / 3 / 2 / CM3 / CM4 / Zero W / Zero 2 W
Open-Source Resources Schematics, 3D files (case), quick start guide
Scope of Delivery
  • 1× Arducam 5MP IMX335 Low Light MIPI Camera Module (B0568)
  • 1× Ribbon cable 15-pin to 22-pin, 15 cm
  • 1× Ribbon cable 22-pin to 22-pin, 15 cm
€ 64,95
Docs MYBOTSHOP documentation
