Arducam 2.2MP Mira220 MONO Global Shutter USB 3.0 Camera
  • SKU: MBS-SES-185-34
  • Category: Sensors
  • Sensor: 1/2.7" 2.2 MP monochrome image sensor with NIR-enhanced global shutter (Mira220)
  • Frame rate: Up to 80 fps with low-distortion M12 lens and high NIR sensitivity
  • Performance: High quantum efficiency (QE) at 940 nm
  • Image quality: Enhanced output with integrated advanced ISP functions
  • Interface: USB 3.0, UVC compliant, plug-and-play, no drivers required
The Arducam UVC3.0 Global Shutter Series Mira220 camera features a 1/2.7" 2.2MP global shutter image sensor, optimized for the near-infrared (NIR) spectrum with high quantum efficiency at 940 nm. Designed for low-light environments, it ensures reliable image capture with excellent detail accuracy.
The sensor supports frame rates up to 80 fps. Combined with a low-distortion M12 lens, it delivers sharp and clear images, even in fast-moving scenes.
An integrated ISP unit enhances image quality through debayering, gamma correction, and color optimization, providing consistent and accurate results.
The camera is UVC compliant and works seamlessly with Windows and Linux systems via USB 3.0, without requiring additional drivers. It is also backward compatible with USB 2.0, making it suitable for a wide range of applications that demand fast and robust image processing.
Applications
  • Mobile facial recognition
  • Active stereo vision / structured light
  • Automatic identification & data capture (e.g., QR code readers, drones)
  • Smart home appliances
  • SLAM for robotics and smart home applications
  • Global Shutter CMOS Sensor: 2.2MP Mira220 with NIR optimization and BSI technology
  • High frame rate: Up to 80 fps for real-time imaging applications
  • Low-distortion M12 optics: Provides sharp and detailed images
  • High NIR sensitivity: Optimized for 940 nm, ideal for low-light conditions
  • On-board ISP: Enhances image quality with debayering, gamma correction, auto exposure control, and RGB2YUV conversion
Image Sensor
  • Sensor: Mira220
  • Still Resolution: 2.2MP
  • Color Filter Type: Mono
  • Shutter Type: Global Shutter
  • Optical Size: 1/2.7"
  • Output Format: YUY2
  • Pixel Size: 2.79 μm × 2.79 μm
  • Active Sensor Area: 1600(H) × 1400(V)
  • Frame Rate (USB 3.0): 1600×1400@30fps, 640×480@80fps
  • Frame Rate (USB 2.0): 640×480@10fps
Lens
  • Focus Type: Manual focus
  • FOV: 80°(D) × 68°(H) × 53°(V)
  • Lens Mount: M12 (S-mount)
  • F.NO: F2.8
  • E.F.L: 3.6mm
  • IR Sensitivity: No IR-cut filter, IR sensitive
  • Default Focus Range: 1 m – ∞
USB Interface
  • Interface: USB 3.2 Gen 1 device, backward compatible with USB 2.0 hosts
  • Connector: Reversible Type-C connector
  • UVC Compliant: No additional drivers required
Electrical and Mechanical
  • Operating Voltage: 5 V ± 5%
  • Operating Temp: 32°F – 158°F (0°C – 70°C)
  • Power Consumption: Max. 1.4 W
  • Camera Board Size: 34 × 34 mm
Functionality and Compatibility
  • Supported OS: Windows, Linux
  • Recommended Applications: PotPlayer (Windows), qv4l2 (Linux)
  • UVC Controls: Brightness, Contrast, Exposure (Manual/Auto)
  • 1 × Mira220 MONO USB3 Camera with back cover and tripod adapter
  • 1 × USB A to Type-C cable (1 m)
Camera Enclosure
from
€ 230,95
  • Must be ordered. Ready for shipment in 7 days after order.
Docs MYBOTSHOP documentation
