Arducam 2,3MP AR0234 Color Global Shutter USB 3.0 Camera Module w/o enclosure
  • SKU: MBS-SES-185-41-02
  • GTIN: 0658917504175
  • HAN: B0495-1
  • Category: Sensors
Arducam 2.3MP AR0234 Color Global Shutter USB 3.0 Camera Module
  • Plug-and-play
  • Sensor: Based on the 2.3 MP AR0234 with a maximum still resolution of 1920 × 1200 pixels
  • Image quality: Integrated proprietary ISP
  • Color Global Shutter: Programmable frame rates, up to 80 fps at 960 × 600 pixels
  • Optics: M12 manual focus lens for precise focusing and a wide 95° (D) field of view
  • Versions: Available in back-cover version (B0495) and enclosure version (B0495C)
The Arducam AR0234 USB 3.0 camera is a high-performance model equipped with a 2.3 MP CMOS sensor (1/2.6") and global shutter technology. It delivers sharp still images with resolutions up to 1920 × 1200 pixels and supports the YUYV format for uncompressed, detailed image output. With frame rates of up to 80 fps, it ensures smooth HD video even in fast-moving scenes.
Fitted with a wide-angle M12 lens (95° diagonal), the camera provides precise, distortion-free image capture.
Integration is simple: with plug-and-play functionality, the camera works instantly on Windows and Linux systems without additional drivers. Full performance is achieved via USB 3.0, while backward compatibility with USB 2.0 adds extra flexibility.
Typical Applications
  • Industrial image processing and machine vision
  • Video surveillance systems
  • 3D scanning and metrology
  • Live streaming
  • Video conferencing
  • High-Quality Imaging: 2.3 MP Global Shutter sensor (AR0234) with max. resolution of 1920 × 1200 pixels
  • Flexible Performance: Frame rates up to 960 × 600 @ 80 fps, M12 manual-focus lens with low distortion and 95° FOV
  • Color Global Shutter: Clear capture of fast-moving scenes without rolling shutter artifacts
  • Advanced Image Processing: On-board ISP with de-Bayering, gamma correction, BLC, AE, AWB, CCM, and RGB2YUV
  • Easy Integration: Plug-and-play, instantly operational on Windows and Linux, no extra drivers required
Image Sensor
  • Sensor: AR0234
  • Still Resolution: 2.3 Megapixels
  • Color Filter Type: Color
  • Shutter Type: Global Shutter
  • Optical Size: 1/2.6"
  • Output Format: YUY2
  • Pixel Size: 3 µm × 3 µm
  • Sensor Active Area: 1920(H) × 1200(V)
  • Frame Rate (USB 3.0): 1920 × 1200 @ 50fps, 960 × 600 @ 80fps
  • Frame Rate (USB 2.0): 960 × 600 @ 10fps
Lens
  • Focus Type: Fixed Focus
  • Default Focus Range: 2m – ∞
  • Lens Mount: M12
  • F.NO: F2.5
  • E.F.L: 3.56mm
  • IR Sensitivity: Integral IR-cut filter, visible light only
  • Field of View (FOV): 98°(D) × 85°(H) × 69°(V)
USB Interface
  • Interface: USB 3.2 Gen 1 device, backward compatible with USB 2.0
  • Connector: Type-C reversible interface connector
  • UVC Compliant: No additional drivers required
Electrical and Mechanical
  • Operating Voltage: 5 V ± 5%
  • Operating Temp.: 32°F – 158°F (0°C – 70°C)
  • Power Requirements: Max: 1.45W, Min: 0.92W
  • Camera Board Size: 34 × 34 mm
Functionality and Compatibility
  • Supported OS: Windows, Linux
  • Recommended Applications: PotPlayer (Windows), qv4l2 (Linux)
  • UVC Controls: Brightness, Contrast, Saturation, White Balance (Auto/Manual), Gain, Exposure (Auto/Manual)
  • 1 × AR0234 USB3 Camera with back cover and tripod adapter
  • 1 × 1m USB A to Type-C cable
Enclosure
€ 166,95
Others also bought:
Docs MYBOTSHOP documentation
