Arducam 2MP Low Light USB Camera Module with M12 Lens
  • SKU: MBS-ARDU-11
  • GTIN: 0658917513528
  • HAN: B0520
  • Category: Accessories
  • High-quality Sony 1/2.8″ CMOS sensor, 80dB range, 95° lens, 1080P30 video.
  • Captures HD in low light for detailed images.
  • Compact 19.5x15x17.3 mm
  • Smallest camera board, M12 lens, CNC metal housing, Type-C and USB-A adapter.
  • Plug & play: UVC drive-free, supports Windows XP/7/8/10, Linux, Mac OS.
Overview
The Arducam Tiny USB Camera is equipped with a premium Sony 1/2.8″ CMOS sensor, delivering exceptional image quality with an impressive 80dB wide dynamic range.
Designed with compactness in mind, the camera measures just 19.5 x 15 x 17.3 mm and features a pinhole lens offering a 95° diagonal field of view. Its miniature design combines the smallest camera board with an M12 lens, all encased in a durable CNC-machined metal housing for efficient heat dissipation.
This UVC-compliant camera is driver-free and compatible with Windows XP/7/8/10, Linux, and Mac OS. It connects effortlessly via USB Type-C or the included Type-C to USB-A adapter, eliminating the need for additional drivers.
Applications
  • Home and security surveillance
  • Video monitoring
  • 3D scanning and metrology
  • Live streaming
  • Nanny camera
  • Superior Imaging: Incorporates a Sony 1/2.8″ color CMOS sensor with an 80dB dynamic range and a conical lens that provides a 95° diagonal field of view, enabling smooth 1080P30 video recording.
  • Optimized Low-Light Performance: Captures detailed, high-definition images even in low-light environments, ensuring reliability in challenging conditions.
  • Compact and Portable Design: With dimensions of 19.5 x 15 x 17.3 mm, this lightweight camera is ideal for portable use with smartphones, tablets, and laptops.
  • Miniature Construction: Features a space-saving camera board paired with an M12 lens, housed in a CNC-machined metal enclosure that enhances heat dissipation. Comes with a Type-C connector and a Type-C to USB-A adapter for versatile connectivity.
  • Effortless Setup: UVC-compliant design ensures easy plug-and-play compatibility with Windows XP/7/8/10, Linux, and Mac OS. Connect seamlessly to PCs, laptops, or Raspberry Pi without requiring extra Drivers.
Image Sensor
  • Still Resolution2 Megapixels
  • Color Filter TypeColor
  • Shutter TypeRolling
  • Optical Size1/2.8″
  • Output FormatMJPG/YUY2/H.264
  • Pixel Size2.9μm x 2.9μm
  • Sensor Active Area1937(H) x 1097(V)
  • Frame Rate (USB 2.0): MJPG: 30fps@1920×1080, 1280×720, 800×600, 640×480, 320×240 | YUY2: 30fps@640×480, 320×240; 10fps@1280×720,800×600 | 5fps@1920×1080; H.264: 30fps@1920×1080, 1280×720, 800×600, 640×480, 320×240;
Lens
  • Focus TypeManual Focus
  • FOV95°(D) ×82° (H)×66°(V)
  • Lens MountM12 Lens
  • F.NOF2.5
  • E.F.L3.7mm
  • TV Distortion<-13%
  • IR SensitivityIntegral IR-cut Filter, visible light only
  • Default Focus Range1m-∞
USB Interface
  • InterfaceUSB 2.0 Device
  • ConnectorUSB Type-C
  • UVC CompliantNo additional drivers required
Electrical and Mechanical
  • Operating Voltage5 V +/- 5%
  • Operating Temp.32°F-158°F (0°C to 70°C)
  • Power RequirementsMax: 1.1W
  • Overall Size19.5×15×17.3 mm
Functionality and Compatibility
  • Supported OSWindows, Linux, Android and MAC OS
  • Recommend Sample ApplicationAmcap for Windows
  • UVC ControlsBrightness, Hue, Contrast, Saturation, Sharpness, Gamma, White Balance (Manual/Auto), Gain, Backlight Comp, Exposure (Manual/Auto)
  • 1 x Arducam 2MP Camera Module with USB Type-C Cable (1m)
  • 1 x USB Type-C to USB A adapter
Shipping weight: 1,00 kg
€ 116,99
Docs MYBOTSHOP documentation
