Arducam 8.3MP Sony STARVIS 2 IMX585 USB 3.0 Camera Module
  • SKU: MBS-ARDU-09
  • GTIN: 0658917513498
  • HAN: B0498
  • Category: Accessories
  • Ultra Low Light Manual Focus
  • 16mm C-Mount Lens
  • Effortless plug-and-play integration.
  • Based on 4K Starvis 2 IMX585, maximum resolution 3840×2160.
  • Integrated, proprietary ISP enables image enhancement.
  • Programmable frame rate, up to 90fps@720p
  • C-mount telephoto lens for precise focusing and versatile remote Framing.
The Arducam USB 3.0 Low-Light Series delivers cutting-edge camera technology, ensuring exceptional performance even in challenging lighting conditions. Equipped with the Starvis2 CMOS IMX585 sensor, this camera captures crisp images at 3840×2160 resolution. An integrated ISP (Image Signal Processor) enhances image quality, while the USB 3.0 interface enables flexible frame rates of up to 90 fps.
The versatile 1" C-mount telephoto lens with an adjustable aperture ensures clear captures across varying distances, offering a 50°D field of view.
This camera stands out with its user-friendly plug-and-play functionality, fully compatible with Windows and Linux. Its backward compatibility with USB 2.0 ports ensures seamless connectivity, providing a hassle-free user experience.
Applications
  • Machine Vision
  • Video Surveillance
  • 3D Scanning and Metrology
  • Live Streaming
  • Video Conferencing
Key Features
  • Advanced Sensor: The 4K Starvis2 IMX585 CMOS sensor delivers outstanding image quality, even in low-light environments, with a resolution of 3840×2160.
  • High-Speed Connectivity: With USB 3.0, the camera streams videos at 720p/90 fps, ideal for use in demanding lighting scenarios.
  • Precision Optics: The 1"-16mm telephoto lens with an adjustable aperture ensures sharp images at varying distances (50° field of view (D)).
  • Enhanced Image Processing: The onboard ISP employs advanced technologies like de-Bayering, gamma correction, BLC, AE, AWB, CCM, and RGB2YUV, delivering superior image quality and accuracy.
  • Effortless Setup: The plug-and-play compatibility with Windows and Linux eliminates the need for additional drivers, ensuring a smooth and straightforward Setup.
Image Sensor
  • SensorIMX585
  • Still Resolution8.3 Megapixels
  • Color Filter TypeColor
  • Shutter TypeRolling
  • Optical Size1/1.2″
  • Output FormatYUY2
  • Pixel Size2.9 µm x 2.9 µm
  • Sensor Active Area3856(H)×2180(V)
  • Frame Rate (USB 3.0)3840×2160@15fps, 1920×1080@60fps, 1280×720@90fps
  • Frame Rate (USB 2.0)1280×720@10fps
Lens
  • Focus TypeManual Focus
  • FOV50°(D) × 41°(H) × 31 °(V)
  • Lens MountC Mount
  • F.NOF1.4-F16
  • E.F.L16mm
  • IR SensitivityIntegral IR-cut Filter, visible light only
  • Default Focus Range5m-∞
USB Interface
  • InterfaceUSB 3.2 Gen 1 device, backward compatible with USB 2.0 hosts
  • ConnectorType-C reversible interface connector
  • UVC CompliantNo additional drivers required
Electrical and Mechanical
  • Operating Voltage5 V +/- 5%
  • Operating Temp.32°F-158°F (0°C to 70°C)
  • Power RequirementsMax: 1.78W  , Min: 0.9W
  • Camera Board Size34×34 mm
Functionality and Compatibility
  • Supported OSWindows, Linux
  • Recommend Sample ApplicationPotPlayer for Windows, qv4l2 for Linux
  • UVC ControlsBrightness, Contrast, Saturation, White Balance (Auto/Manual), Gain, Backlight Comp, Exposure (Manual/Auto)
  • 1 x IMX585 USB3.0 Camera Module with Case
  • 1 x 1m USB A to Type-C Cable
Shipping weight: 1,00 kg
€ 309,95
