FrSky Taranis Radio System Q-X7
  • SKU: MBS-DR-71
  • GTIN: 0658917505011
  • Category: Drones
  • black
  • with LBT
The FrSky Taranis Q X7 ACCESS is an ergonomic 2.4 GHz transmitter with up to 24 channels. Thanks to its high-speed digital module interface it offers a higher baud rate and lower latency; a haptic vibration module as well as voice and tone output provide convenient feedback. The open-source OpenTX is used as the operating system.
Like all ACCESS transmitters, the Q X7 offers a secure, reliable link and wireless firmware updates, making it fully compatible with OTA receivers. The external module bay also accepts third-party RF modules – in combination with the FrSky XJT module, up to 32 channels are possible. An SD card slot provides practically unlimited model memory, while a USB port serves updates, data transfer and charging of the transmitter batteries (2× 18650 Li-Ion).
The ball-bearing gimbals can be set to the desired mode via screws. Full telemetry capability, RSSI signal-strength feedback, a backlit display readable in sunlight, as well as an audio and trainer jack (teacher/student operation / simulator) round off the feature set.
  • ACCESS transmission protocol
  • ergonomic, compact design; open-source operating system (OpenTX)
  • spectrum analyzer function; high-speed digital module interface
  • quad ball-bearing gimbals; Receiver Match
  • audio voice output (values, alarms, settings); vibration alarms
  • real-time flight data logging; RSSI warnings; super low latency
  • wired trainer function; model config compatible with Taranis X9D Plus
  • easily accessible battery compartment (adaptive for 2× 18650 Li-Ion)
Technical specifications
Dimensions 202.2 × 189.4 × 96 mm
Weight 613 g (without batteries)
Number of channels 16 (ACCST D16) / 24 (ACCESS)
Operating voltage 6–8.4 V
Operating current 165 mA at 7.4 V (typ.)
Operating temperature -10 to +60 °C
Display backlit LCD 128 × 64, readable in sunlight
Model memory 60 (expandable via SD card)
Connectors Smart Port, Micro-SD slot, Mini-USB, DSC port
  • 1× Taranis Q X7 ACCESS, black, Mode 2 (mode changeable)
  • 1× quick start guide (German)
  • 1× neck strap
  • 1× USB data and charging cable
  • 1× 4 GB SD card
Note: Without battery. The transmitter batteries (2× 18650 Li-Ion) are not included and must be ordered separately.
Shipping weight: 0,90 kg
Item weight: 0,61 kg
€ 142,95
Docs MYBOTSHOP documentation
