Holybro CAN Hub 27cm
  • SKU: MBS-Z-400
  • GTIN: 0658917504861
  • HAN: 18085
  • Category: Accessories
  • Power input: XT30
  • Expansion: 1x CAN input to 4x CAN outputs
The Holybro CAN Hub is an active expansion module for CAN interfaces that allows a single CAN port to be expanded into up to four ports. At the same time, the module provides a stable and independent power supply for connected CAN devices. Thanks to the integrated step-down voltage regulator, a constant 5V output is ensured, regardless of fluctuations from the flight controller. The CAN Hub is ideal for applications with multiple CAN devices such as GPS modules, ESCs, or sensors in drone and robotics systems.
Technical Data
  • Input voltage: 2S – 12S LiPo
  • Output voltage: 5.2V ± 0.15V
  • Max. current per CAN port: 1.0A @ 5.2V
  • Max. total current: 3A
  • Power input: XT30
  • CAN input: GHR-4V-S (Pixhawk standard)
  • CAN outputs: 4x BM04B-GHS-TBT
Scope of Delivery
  • 1x Holybro CAN Hub
€ 34,99
Docs MYBOTSHOP documentation
