Pixhawk Jetson Baseboard Only w/ case
  • SKU: MBS-ENTB-121-09
  • GTIN: 0658917503864
  • HAN: 11072A
  • Category: Pixhawk
Pixhawk Jetson Baseboard Bundle Pixhawk Jetson Baseboard Only w/ case
  • Standardized PAB form factor
  • Compatible with all PAB-based flight controllers, such as the Pixhawk 6X
  • Offers maximum flexibility for modern UAV and robotics applications
The Holybro Pixhawk Jetson Baseboard combines the open-source Pixhawk Bus (PAB) specification with the powerful NVIDIA Jetson Orin NX/Nano Carrier Board. With its PAB form factor, it is compatible with any PAB flight controller, such as the Pixhawk 6X, making it an ideal solution for advanced UAV and robotics applications.
  • Compact, high-performance integration – combines Pixhawk flight control with NVIDIA Jetson computing power on a single board
  • Versatile connectivity – Jetson and Pixhawk communicate via UART, CAN, and an integrated Ethernet switch
  • PAB form factor – ensures compatibility with a wide range of PAB flight controllers
  • Jetson compatibility – supports Orin NX and Orin Nano
  • Expansion options – two M.2 Key slots for Wi-Fi/Bluetooth modules and NVMe SSD storage
Flight controller
Aluminum Outer Case
Companion Computer
€ 514,95
